Build Advice Graphics Card Advice
Discussion in 'Hardware' started by neocleous, 29 May 2018.
  1. neocleous
    neocleous Minimodder
    12 Feb 2002
    Hi all,
    I’m setting up a new rig for productivity not gaming and I am going to be running two 4K displays.
    Which nVidia GPU can drive two 4K screens without issue?
    Thanks
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    Define productivity? @Gareth Halfacree can be productive with just a Commodore64 and a CRT.
  3. Gareth Halfacree
    4 Dec 2007
    Yer darn tootin' I can. 40 columns is enough for anyone, dammit.
  4. RedFlames
    23 Apr 2009
    Quadro P400, will do up to 3x 4k screen and will do it without issue.
    EDIT:
    If you don't mind mixing and matching between HDMI and DP, you should get away with a GTX1050, or maybe even some flavours of GT1030.
    If you decide on the red corner then you're looking at the Radeon Pro WX2100 or an RX550 with the same caveats as the GTX1050
  5. neocleous
    12 Feb 2002
    Thanks for the reply everyone, bitcoin mining has overly inflated the price of these aging cards so much!
  6. TheMadDutchDude
    23 Aug 2013
    Not so much... it's mostly the short supply of DRAM/VRAM causing major issues.
