Graphics Graphics card length/power reqs
Discussion in 'Hardware' started by she'shighvoltage!, 27 Nov 2009.
  1. she'shighvoltage!
    she'shighvoltage! What's a Dremel?
    24 Sep 2009
    I'm currently running a bumped-up prebuilt system- I replaced the PSU with a pretty no-name 500 watt (Zumax? I got it for $50, so I don't think it's exactly brimming with quality) and put a 9800 GT in the PCI-E slot.
    What's the best graphics card that can be powerd on a 500 watt PSU with one 6-pin?
    (Also, I need to measure my case to find the longest card that would fit.)
  2. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    For that matter, could we compile a list of GPU card lengths, and have it stickied?
  3. Elton
    23 Jan 2009
    Currently, I'd say the HD5770.
  4. she'shighvoltage!
    24 Sep 2009
    I was thinking along the same lines.
    I need to get a ruler out and measure my case, though, I might be able to fit a 5850 if I get a new PSU as well.
  5. Elton
    23 Jan 2009
    Incidentally, what is your PSU?
  6. she'shighvoltage!
    24 Sep 2009
  7. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    that or the 4870 the 4870 is a faster and better card but not by much lol
  8. Elton
    23 Jan 2009
    I'd side with the HD4870, but seeing as it's a hair faster but more power hungry I didn't choose it.
    You can always try to hunt for a HD4890, which still has plenty of stock, but it'll need 2 PCI-E power pins, and is pretty hungry in terms of power. You can push a HD4890 on that,but you'll need a molex--> PCI-E connector, and there might be the problem of overloading your PSU if it's a cheap one(never heard of Zumax).
  9. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    You managed to find a PSU with one six pin PCI-e?!. From that I doubt its output is anywhere near 500w anyway...
  10. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    You'd be surprised, my old generic 400w was 400w BUT there was only 216w available on the all important 12v rail :hehe:
  11. she'shighvoltage!
    24 Sep 2009
    I'm wondering how much my PSU can actually spit out...
    Well the Bit-Tech charts says the 5770 is shorter than an ATX mobo and also eats up less power than the 8/9800 GT I'm running, so I think I'll be fine aiming for one.
  12. Sh0cKeR
    21 Aug 2009
    I was meaning the total output, not just the 12v. Hazard a guess and its more like a 350-400 psu than a 500.
  13. MrWizerd
    MrWizerd What's a Dremel?
    29 Nov 2009
    I would definitely agree that with that power supply since the true voltage output is probably a great deal less than advertised you would probably be happier getting the 5770, I have one and its an awesome card and its tiny (a lot smaller than the x1900 it replaced) and since its using a smaller nm chip its a LOT less power hungry than other cards.
