Graphics Graphics card making odd noise...
Discussion in 'Hardware' started by tech, 26 Apr 2004.
  1. tech
    tech What's a Dremel?
    26 Apr 2004
    It seems lately that a strange noise has been coming from my computer (something like that of a wire in a fan). After inspecting it thoroughly multiple times I noted that the noise seemed to be eminating from the graphics card fan. However there seemed to be no obstructing wires or any wires in the relative area. The sound can get quite annoying but it seems to get more intense when playing any games although it doesn't seem to be affecting the performace of the card.
    Any ideas?
    Specs
    AMD Athlon 2400+
    EPOX 8RDA+ (latest drivers)
    Asus Geforce4 Ti4200 8X (latest drivers)
  2. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    the voltages might be too high for that fan, which is causing the fan to spin much faster than it normally should. I had the same problem on my xbox, but with a few modifications, its pretty much silent. :dremel: is your friend.
  3. tech
    26 Apr 2004
    How would I go about doing that?
  4. Anator
    Anator What's a Dremel?
    26 Feb 2004
    If your fan is detachable then try taking it off and giving it a good clean - always worth a shot.
  5. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    It's probably just a dodgey fan mate. How old is the card?
  6. tech
    26 Apr 2004
    Card...
    Card is not that old, maybe half a year.
  7. Redimp
    Redimp What's a Dremel?
    16 Aug 2003
    I agree, maybe you could unplug the fan to see if the noise stops. (only for a short time though!)
  8. ViRuZO
    ViRuZO What's a Dremel?
    14 Apr 2004
    your card may have a cooling spoilage :worried:
  9. jetsetjimbo
    19 Feb 2003
    Just stop the fan with your finger - i bet the nosie stops.
    I have had fans fail in this whiney way before, they can just fail...
  10. tech
    26 Apr 2004
    Hm...
    I would remove the fan, but I have no idea how to get the little pegs holding them down off. They seem to be in two parts, you can push them together or pull them apart a bit but they don't come off.
    Here a pic of what I'm talking about, the little black pegs on the corner of the gold fan cover. http://usa.asus.com/products/vga/v9280td/v9280td_l.jpg
  11. cderalow
    cderalow bondage master!
    23 Jan 2002
    i actually have that same card (the 128MB version) and the fan is whiney in general.... chances are its not failing.... its just being itself
    as to getting the cooler off, i've found that a universal molex pin tool works wonders to popping the pegs out
    mainly you need to compress the pin in towards the card, then squeeze the little pointed parts on the back together then push them out through the card...
    tough to do at times, but once you get the hang of it, quick & easy
  12. Heavytank2
    Heavytank2 What's a Dremel?
    10 Oct 2003
    I've had two fans go out on my graphics card, one of them actually stopped, and I am glad I had my case open to catch it. But, my crystal orb is making VERY loud noises. Vibrating, grinding, etc. Thus is why I am replacing it with a Vantec Iceberq 4 non-pro (24dba, woot!). One thing you can try is getting some thick silicone oil, about 40-50wt (RC car shock oil) and pulling off the label covering the shaft and add some there. Few drops should do. This stopped the noise for a while, but I only had light spray oil.
    If you want to have pictures of this, just look up the DIY Painted fan tutorial on this site.
