Graphics Graphics card not working
Discussion in 'Tech Support' started by Elspuddy, 2 Jul 2010.
  1. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    Right I'm replacing my 3450 with a nivida 8800 , my psu in the other rig is 400w and dose not have a pci-e power wire, I did by a dule 4 pin molex to pci-e wire but the card will not work even with all the hard drives unplugged , looking at the molex to pci-e wire it looks like it's missing a wire ( bottom row middle wire, could this by why it will not work also what wire is missing ?
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    try plugging it into 2 separate rails coming from the psu with the dual 4 pin molex adapter
  3. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    just tryed this and still no bleeps and no picture on screen
  4. rollo
    rollo Modder
    16 May 2008
    does the fan spin ? when you turn it on as you dont need a the pci lead to get the fans to spin.
    if the fan spins its a psu problem
    if the fan doesnt spin the graphics card or motherboard.
