Graphics graphics card temps??
Discussion in 'Hardware' started by fluf_art, 28 Feb 2004.
  1. fluf_art
    fluf_art What's a Dremel?
    15 Feb 2004
    hi peeps!
    I have a ati 9700 128meg card(non pro) how would i find out how to monitor
    the temp of the core :confused: :confused: i do run mbm5 but this is for the motherboard and wont support graphics cards(well,as far as i know!) i dont want to do this with a multimeter as it is to much hassle, is there any apps
    that would support this :confused:
    thanks
    fluf_art
  2. dom_
    dom_ --->
    4 Jan 2004
    i just updated the catalyst drivers for my 9800xt and now when i goto advanced under display properties, then under the overdrive tab i have a temperature readout. Although i was shocked to read it was 72 degrees after only 2hours of farcry gaming.
  3. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    F or C? 70 Degrees Celcius is not good for your gpu. It'll fry in due time at that temperature.
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Unless you manually attatch a temp sensor there probalby isnt any way to monitor temps... the new XT's have thermal diodes but i dont think other cards have them installed
  5. You are correct.
  6. fluf_art
    15 Feb 2004
    oh well it was worth a look :sigh:
    thanks for your help all :cooldude:
    fluf_art
  7. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    although the high end Geforce FX's have a temp sensor too :)
  8. Mister_Tad
    27 Dec 2002
    GPUs can handle much hotter temps than CPUs
    for instance, the clock speeds on many GeforceFX cards doesnt start to throttle back until it its somewhere around 110C
    Nvidia drivers dont shut my card down until it reaches 140C
