Graphics Graphics card upgrade?
Discussion in 'Hardware' started by Kronos, 16 Oct 2010.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
  2. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Well it's really going to depend on the expansion slots he has available, the amount space inside the case (it looks quite small), and the PSU. The spec looks reasonably new so I'm guessing it has a PCI-E x16 slot, but the PSU that came with the system will likely be the bare minimum in terms of wattage and will definitely be of very low quality, which makes upgrading the GPU tricky without first upgrading the PSU.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    My thoughts exactly, I will try and find and find out the psu.
  4. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    HI, if he has a full height slot then a 5670 would be a good move, if it's half heigt then i think a 5570 is as fast as you can get.
    These are both low power cards so PSU should be OK.
