HTPC Graphics Card
Discussion in 'Hardware' started by stepea, 16 Feb 2014.
  1. stepea
    stepea What's a Dremel?
    13 Dec 2009
    Looking for a graphics card for xbmc (Linux) - any recomendations.
    Sent from my ASUS Transformer Pad TF300T using Tapatalk
  2. faugusztin
    11 Aug 2008
    You don't really need a graphics card these days for that... If you got a Sandy/Ivy Bridge or Haswell system, you good to go. In case of other systems it isn't that clear cut, can you tell us more about your HTPC system ?
  3. stepea
    13 Dec 2009
    I'm using an old core duo system to be the heart of the system, it hasn't got HDMI, so I need a graphics card.
  4. Bede
    Bede Minimodder
    30 Sep 2007
    Budget?
    If you're not gaming get one of the cards that only draws power from the mainboard.
  5. stepea
    13 Dec 2009
    Something inexpensive that has an HDMI output. No gaming, media player only.
  6. Parge
    16 Jul 2010
    5450 would be my choice
