Graphics Graphics distortion when running games
Discussion in 'Hardware' started by schismpunk, 16 Mar 2005.
  1. schismpunk
    schismpunk What's a Dremel?
    16 Mar 2005
    I've recently been getting a graphics error when running games. The games start out fine but after about 5-10 minutes they freeze for about 10 seconds and then my graphics look like this. The game is still playable, though very annoying. I have to restart my machine to fix the problem. The problem occurs in Counter Strike: Source, Sims 2, and Delta Force BHD, but it may happen in other games too. No error message pops up.
    Specs:
    Athlon XP @ 2.1 Ghz
    Geforce FX 5600 256MB
    1200 MB DDR 2100
    XP Pro w/ SP2
  2. TMM
    TMM Modder
    12 Jan 2004
    Either an overheating Core or bad memory. Check that the Heatsink is making good contact with the Core and that the fan is spinning ;)
  3. schismpunk
    16 Mar 2005
    yup, fan's not spinning. That would be a problem... am I likely to cause any damage to my card if I continue to use my machine for non-graphically intense purposes?
  4. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    You might damage it, yes. Unless you underclock it enormously, that's what I do with my old amd k6-2 CPU when I don't want the 40mm fan whining away. Not really comparable but you get the idea. Get a new fan and you'll be set ;)
