Grease for rubber o ring on barb
Discussion in 'Watercooling' started by b1g-d0g, 27 Jan 2021.
  1. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    I have the EK water block that cools the vrms on my Asus maximus xii formula z490 motherboard,there are 4 barbs that screw on the vrm and cpu blocks with a rubber o ring,the way it's fitted is you remove a screw from the vrm block and slide it then you lube the barbs they did Inc some grease but there is not enough press down then slide over the top part then replace the screw and tightin.
    So what grease can I use for it.
    Thanks
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Lithium grease is ideal for o-rings, plus a great many other things.
  3. The_Crapman
    The_Crapman Don't phone it's just for fun. Staff
    5 Dec 2011
    Could try contacting their support and ask for more?
  4. Cheapskate
    13 May 2007
    Plumber's silicone grease. -Literally made for slicking up O-rings.
    Osgeld and cobalt6700 like this.
  5. Big Elf
    23 Apr 2009
    I've been using a high quality silicon grease on 0 rings for years.
    If the fitting has been connected and in use for more than a couple of months I also replace the 0 ring whenever the fitting is removed.
    cobalt6700 likes this.
  6. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Would recommend a silicone grease over a petroleum based grease - they can sometimes cause o-rings to break down (depending on o-ring material, petroleum products will attack natural rubber). :)
    Big Elf and Arboreal like this.
  7. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Second a silicone grease, I use a specialist silicone grease for vacuum o-rings and they're good for years.
  8. dan297
    dan297 Modder
    28 Jan 2021
    I always use "Team Associated Green Slime". No kidding, that is the brand name.
    It is made for greasing RC car shock absorber o-rings.
    I grease all fittings with this and tubes slide in like a breeze.
    Should work for your purpose too...
  9. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Thanks for the help,I contacted ek and they said there should be plenty of thermal paste had to reply it's not that I need duh.
    So I've ordered a small tube of silicone grease was only £2.50
  10. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    I've never watercooleed but when servicing brake calipers and replacing the o-rings we use plumbers silicon grease too.
    Link to the tube i'm about to use in the next hour
  11. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Thanks for the offer mate,I recived the silicon grease I ordered from the bay :dremel:
