greased cat 5 cable?
Discussion in 'General' started by chrisb2e9, 4 Sep 2008.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I wanted to run about 200 feet of cat 5 cable underground but our IT guy says that it has to be a greased coax cable.
    I've tried looking it up but as far as I can tell its just means waterproofing it.
    What exactly is a greased coax cable?
  2. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Why not just run CAT-6 STP? Nice and thick, lots of shielding. Pretty cheap in large quantities too.
  3. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    huh? coax cable != cat5 cable. sounds to me like your IT guy is full of crap. just grab some conduit and run the cable through it. the site i was working on this summer had cat5 cable running underground between all the security centers, and it was just standard cat5e inside this stuff. and the cable for our in-ground sprinkler system control boxes was just unprotected cat5 buried 18" below the surface.
  4. chrisb2e9
    18 Jun 2007
    Sorry for the confusion, its the "greased" part that I dont understand. What we have is a cat-5/coax cable.
  5. DougEdey
    5 Jul 2005
    You can't have Cat5/Coax, they are completely different and distinct technologies. Coax is the stuff you get to run TV with, over here it's used for Cable TV and Satellite TV (both "thick") and there's a thin one for analogue/internal connections.
    Cat5 is twisted pair cable.
    If your IT Guy says you need greased Coax then it's probably a crock of crap.
  6. RTT
    RTT #parp
    12 Mar 2001
    tell him that he needs a vga cable for his microwave
  7. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I thought they were esata these days?
  8. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    If he was serious, LOL! If not he totally took you for a ride! :D
    This also reminds me of things that military guys do to new recruits that have no clue as to what they are doing! Like getting grease from the kitchen for the 'after burners'. :D
  9. liratheal
    20 Nov 2005
    "Do you sell headlamp fluid?"
  10. talladega
    talladega I'm Squidward
    18 Aug 2007
    At my last job they had me go look for the 'wood stretcher' LOL. Luckily someone told me it wasnt real. They onetime had a guy looking for it for 2 hours.
    Anyways heres what I get when I search for 'greased coax'
  11. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Roll your own. All you need is a water based lube, like KY Jelly, and the cable. For fun you could use Anal-EZE. That would put a spin on the data.
  12. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    You can get "outdoor" cat5, which is just a bit tougher than the normal stuff. That's probably your best bet.
  13. Firehed
    15 Feb 2004
    Woah.
    Please refrain from employing your photographic skills on this subject.
  14. ToMMo
    ToMMo What's a Dremel?
    5 Dec 2007
    Does it make the data move faster as there is less friction :hehe:
  15. mushky
    mushky gimme snails
    24 Mar 2003
    By greased he means jelly filled.
    but you dont really get jelly filled coax cables, only multi-paired cables.
    And the jelly filling does not make it waterproof. The outer sheath does that.
    depends if you are doing a direct burial - if so get steel wire armoured SWA, but again thats not a coax variant.
    What are you trying to achieve?
    Basically your IT guy doesn't have a clue.
    Standard cat5 will not stop water and moisture ingress, but it is resistant. It IS fine on the outside of a building or something for ages especially if it is black.
  16. mushky
    mushky gimme snails
    24 Mar 2003
    Is it just for ethernet?
  17. kennethsross
    kennethsross What's a Dremel?
    29 Jul 2008
    Not sure how up to date your IT guy is, but last time I put in a coax-based network was probably '95 or '96.
    By 'greased', he may be referring to a cable that has a lubricant coating, to reduce friction when pulling through conduit.
  18. mushky
    mushky gimme snails
    24 Mar 2003
    I'm pretty sure he's talking about a petroleum jelly filled cable, which is common for multi-pair external applications, but I'm talking like 50 pair plus
  19. chrisb2e9
    18 Jun 2007
    yeah this is just for internet.
    and I dont know what I was smoking last night. Guess this is what happens when you watch two seasons of scrubs in one day. Forget I even mentioned coaxe. Maybe I had that on my mind for the VHF antenna that I am setting up later on, it uses a coaxe cable.
    This is just cat 5.
  20. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    Make sure it's left handed too or you will be sorry.
