Cases Great question about switching case 650D Vs 700D
Discussion in 'Hardware' started by Marcos_Viegas, 31 Jul 2011.
  1. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
  2. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    the 650D should be better for aircooling since its got a 200mm fan at the front of the case.
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    700d is bigger and I usually used for water-cooling.
    650 is mid tower and is a better air cooler.
    I wouldn't swap unless you are going to wc.
  4. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    I would also stick with the smaller build unless you are going to watercool. Even if you were going to watercool, it would be cooler in my opinion to squeeze it all into the 650.
  5. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    700D is a colossal case like the 800D, however the air cooling isn't great (I had the 800D and ditched it for a Raven as I'm air cooling).
  6. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
    +1 on this..
    800d is terrible on airflow as well.
  7. Marcos_Viegas
    6 May 2010
    By the stylish, the 650D is good, but i'll change the window, and i'll go to buy another panel, but the 700D have more place to put a WC, and that is my goal.
    Anyway, the 700D is best for WC wich the 650D?
  8. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    700d is a discontinued model hence the reason I purchased the 650d....
  9. fdbh96
    29 May 2011
    Hasn't been discontinued has it?
  10. Marcos_Viegas
    6 May 2010
  11. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
  12. oatey4519
    5 May 2009
  13. Sentinel-R1
    13 Oct 2010
  14. oatey4519
    5 May 2009
    Mmm
    Like the look of this.. thanks for the info
    Never used this site.
  15. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    +1. They're both designed with different purposes.
