Grrr bios
Discussion in 'Hardware' started by Nedsbeds, 24 Jun 2002.
  1. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    im having a spot of trouble. Xp is playing up on one of my computers. a bios update fixed it on my other machine, but on this one awdflash just tells me that the update is incorrect for my motherboard. im pretty sure its not because it came from the manufacturers website (www.jetway.com.tw). is there a way of bypassing the protection in awdflash or do you not recommend it?
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Theres a reason for that proctection, and I don't recommend using a bios from another source other than the manufacturers website unless its a modded bios.
  3. Nedsbeds
    16 May 2002
    does anyone have any ideas ehy it wont update then?
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    if awdflash tells u its the wrong one, then that is for a reason...tried contacting the manufacturer???
  5. Nedsbeds
    16 May 2002
    ive done some investigating and it turns out that they put the wrong chipset number on the front of the manual. its right inside the manual though. thanks for replying and trying to help.
  6. herbs
    7 May 2001
    lol, thats why there is protection when you flash you bios :D . But hey we all make mistakes.
