Networks grrr network no longer workin
Discussion in 'Hardware' started by samuelellis, 25 May 2002.
  1. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    i have started to build up my new rj45 network (bye bye bnc) anyway i jsut got a lenght of crossover to runt inbetween the laptop & desktop (as a temp measure intil ican afford to do it properly) & ther enot talking i have tried netbeui, ipx/spx & tcp/ip on both machines (ie both machines have netbeui, both have ipx/spx & both have tcp/ip) but they still can see each other, i know there both sending information out as i can see the light on my laptops media coupler (the bit that lugs on to my laptopls network card) but they dont see each other, any ideas?
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Get rid of ipx/spx you dont need it unless you play red alert. Set the ip on each card to say 192.168.0.1 and 192.168.0.2, reboot.
    Then try to ping each machine, if that works good, if not then uninstall tcp/ip and re-install. If that doesn't work un-install the cards and re-install them. Also if you can try another x-over cable, to rule that out.
  3. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
  4. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    if your not using the internet, for sake of simplicity only use NetBeui for the protocols, it has nothing to setup.. if on the net, use only TCP/IP, more protocols only confuse things..
    Secondly have you tested the cable or tried another?
    -scoob8000
  5. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    what os are you running?? if its win2k or xp make sure they are in the same workgroup/domain...
  6. samuelellis
    19 Apr 2002
    cheers lads, i traced it back to a faulty piece of crossover cable
  7. scoob8000
    17 Feb 2002
    That'll do ya.. :) fleabay has some elcheapo cable testers for around 20$ us btw.. just happened to see them a few weeks ago when I was shopping for a new TDR..
    -scoob8000
  8. felix the cat
    11 Jan 2002
    either that or test it on a workin network....
