Windows grrr... task manager problem
Discussion in 'Software' started by bAnTAi, 8 Dec 2003.
  1. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    when ever i bring up the windows task manager, it disappears after a second or two, never long enough to do what i want. I reinstalled windows and it worked fine for a bit, but has since stopped. I assume it's some piece of software i've installed. Anyone got the same problem or know a fix for it?
  2. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Have you done a virus check with an up-to-date scanner?
    AVG (it's free) can be found here
  3. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
  4. bAnTAi
    19 May 2002
    ta v. much.....i did search, but nothing came up
