Planning [GT] Cube mATX , by iD2
Discussion in 'Modding' started by iD2, 17 Oct 2013.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Welcome!!!​
    See all project at my blog here :: iD2CNC.wordpress.com
    Project Name :: [GT] Cube mATX
    Project concept:: It not just system, It your style
    Specification ::
    - Materials:: Acrylic
    - Colors:: Black/White
    - Tags Colors:: Red/White/Yellow/Green/Blue/Orange
    - Motherboard Sizes: mATX
    - 5.25″ Drive bays:: 2
    - HDD 3.5″:: 2
    - HDD 2.5″:: 2
    - Power Supply:: 2
    - Cooling Rear:: 1 x 120mm
    - Cooling Top:: 3 x 120mm
    - PCI Slots:: x 4
    - Radiator thickness:: 30/35mm (will fit with 45mm thickness)
    - Maximum CPU Cooler Height:: 165mm
    - Dimensions (WxHxD):: 300 x 330 x 482mm
    - Radiator support:: 1x 240mm / 1x 360mm
    Features ::
    - Support Right-Hand Style /Left-Hand Style
    - 4 x Front panel style
    - 6 x Front tags color
    - Transparent side panel
    - Transparent front panel
    - Transparent GPU panel
    - Cable management
    Multiple Tags Color ::
    6 Colors Tags , compatible with components ::
    Detail ::
    Drawing Detail ::
    Support Both Right-Hand Style cases or Left-Hand Style cases ::
    Get 4 Style font panel :: (Just flip it)
    All Project by ::
    Hope you like it.
    PS. I'm not good in English , If i make you confuse please feel free to ask me.
  2. iD2
    iD2 Minimodder
    25 Mar 2012
    Need sponsor , how to contact them. I can not find it from "contact us" section.
  3. Nexxo
    23 Oct 2001
    Nice concept.
    Bit-Tech does not offer sponsorship. You have to approach companies directly.
  4. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you , i try to contact to direct sponsor but i can't find how to contact to anyone who have proper authority.
  5. iD2
    iD2 Minimodder
    25 Mar 2012
    Before start new project for build acrylic computer case from scratch i just need to lift CNC up because it not convenient when using CNC and re-wiring limit switch by using shields wire to protect noise from spindle and stepper motor, After finish it make my small room look very small than ever.
    Wood table base ::
  6. iD2
    iD2 Minimodder
    25 Mar 2012
  7. iD2
    iD2 Minimodder
    25 Mar 2012
