Windows GTA: SA - Problems starting
Discussion in 'Gaming' started by hacker 8991, 8 Jul 2005.
  1. hacker 8991
    hacker 8991 What's a Dremel?
    8 Jan 2004
    Grand Theft Auto: San Andreas is refusing to start on my computer. It worked fine until this morning, at which point it stopped starting.
    I have scanned for spyware and viruses, rebooted, and reinstalled the game, but it still won't start. When I try to start it (from the desktop icon or CD autoplay button or from the *.exe), the hard drive churns for a few seconds and the cursor changes to a CD, but nothing happens. The process list shows gta_sa.exe for a few seconds, but the game does not actually start.
    System specs are as follows:
    Gigabyte GA-7N400XP
    Athlon XP 1800+
    ATI Radeon 9600 Pro
    512MB RAM
    20GB IBM Beskstar 7200RPM
    Samsung CD Burner/DVD Player
    The strange thing is that the game was working yesterday, and now has suddenly stopped. Any ideas are appreciated.
  2. shroom
    shroom What's a Dremel?
    6 Aug 2003
    When you say it 'stopped starting' do you mean you double click the shortcut and nothing happens?
  3. mushky
    mushky gimme snails
    24 Mar 2003
    Try uninstalling and then reinstalling it. Your save files will remain.
  4. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    He said he reinstalled it. Reboot, bring up task manager and kill off every unnecessary process and try again.
  5. hacker 8991
    8 Jan 2004
    I tried everything that you guys posted, but they didn't help.
    Then, unexpectedly, it started the next day.
    :confused:
  6. ou7blaze
    ou7blaze sensational.
    5 May 2003
    well sometimes thats how computers work :rolleyes:
  7. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Yep it's a very common problem. Go to your save game directory (in My Documents) and delete the config file for the game settings (controls etc) and try again. I SHOULD start this time. However be warned, your save file could be corrupted. This happened to me a number of times for no apparent reason, however the common theory is down to some erratic hostility between the game and XP user accounts.
