Graphics GTX 1080 boost clock stuck at low speeds after PC has been idle few days.
Discussion in 'Hardware' started by sew333, 1 Aug 2016.
  1. Deders
    Deders Modder
    14 Nov 2010
    No difference. Still drivers.
  2. law99
    law99 Custom User Title
    24 Sep 2009
    Tbh... I've thought long and hard about thisl. Have you considered burning your house down?
  3. Deders
    Deders Modder
    14 Nov 2010
    @Law99: Really not sure how this would help
    @Sew333: Before you ask, no, don't burn your house down.
  4. GeorgeK
    18 Sep 2010
    sew333 - I would be almost 100% certain that your card is absolutely fine and am 100% certain that you need to stop asking about it and just play some goddamn games on it. Occasionally if my PC has been on for a while I'll notice that one of the cards in my rig doesn't boost up to full power which is always solved by a restart of the computer.
    GK
  5. Mr_Mistoffelees
    26 Aug 2014
    Why would you leave your PC at idle for a few days? Just shut it down when you aren't going to use it for a long time.
  6. jinq-sea
    15 Oct 2012
    If the clock speed gets stuck, reboot your PC. Simple. Things sometimes go 'weird' if hardware is in a low power state. Or (and especially in the summer), shut it down when it's not being used! :thumb:
  7. law99
    24 Sep 2009
    If you raise the house, and everything in it, the problem has been incinerated.
    Anyway, I'd stop leaving my PC on for days at a time on idle ...
  8. sew333
    sew333 What's a Dremel?
    12 Oct 2012
    What is your graphic card?
  9. sew333
    12 Oct 2012
    Update: pc was 2 days on idle and throttling occured again. Pc restart fixed again.
    Note from geforce forum:"If you are running a Pascal GPU (GTX 1080/1070/1060), please test with the Power Management Mode in the NVIDIA Control Panel set to Adaptive (default is Optimal power) and let me know if you hit the same stuck low clocks after an idle period."
    I have optimal power. Maybe choose to adaptive? But some user reported it not helped.
  10. GeorgeK
    18 Sep 2010
    2 x GTX 780s. Like others have said - just turn off your pc when you're not using it! Why leave it idling for 2 days?
  11. Elton
    23 Jan 2009
    To add, this has basically happened to every series of Nvidia card I've used since the GTX 6xx series. Basically it's just a power saving feature that sometimes doesn't "wake up".
    I wouldn't worry about it, rebooting the PC usually fixes it, and if you REALLY can't be bothered just use the EVGA KBoost (that turns off all of that and runs the card at full tilt constantly.). Rebooting will be perfectly fine though.
    The next release of drivers should fix it, but my GTX 780, 680, and 970 all had this happen once in a while. Nothing to worry about carry on!
  12. law99
    24 Sep 2009
    I've started leaving my car on after I park. I'll let you know if it develops any issues.
  13. Deders
    Deders Modder
    14 Nov 2010
    It doesn't just happen after 3 days or so, it's happened overnight for me.
  14. law99
    24 Sep 2009
    Well... I woke up this morning and my car is gone. I've been in Nissan forums and it is totally a bug. However, I could, like, apparently, just turned my car off and it would still be here this morning. So confused.
  15. Deders
    Deders Modder
    14 Nov 2010
    Have you tried turning it off and on again?
  16. law99
    24 Sep 2009
    It's gone.... I'm not sure what to do. I've bought another car. But it is more convenient to me if I leave it on, idling.
  17. Deders
    Deders Modder
    14 Nov 2010
    See if it happens again, if it does then feel free to write a strongly worded letter to the manufacturer.
