Graphics GTX 275 watercooling
Discussion in 'Hardware' started by Taffy, 13 Aug 2009.
  1. Taffy
    Taffy Folding for Margaret 17/3/2011 RIP
    23 Apr 2009
    Hi Guys, Scan are advertising a watercooling block for the GTX275, however they add a warning that they are for a VGA PCB, can anyone tell me how to check this on my Palit GTX275, many thanks in advance
  2. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    Just giving you an good option here..
    Go to Scan Contact Clicky and ask them via email, quoting your card part number and the part you wish to purchase.
    You should have an answer with a day or two and be sure that if there is any problem in installation you have a fall back..
    Scan deserve some credit, def give themn your business, they aced out all of my orders.
  3. trig
    trig god's little mistake
    10 Aug 2006
    just a shot in the dark, because i next to nothing about water-cooling, but isn't that just stating that it's for a graphics card?
  4. Fazed
    Fazed Minimodder
    5 Jul 2009
    IIRC, the Palit GTX275 use a modified GTX285 PCB?
  5. Combatus
    16 Feb 2009
    If you have no luck with scan you could try the manufacturer of the block - I know EK blocks and the like are normally fairly good at listing cards it's not compatible with (saying that I did need to mod my 3850 block so it didn't foul a cap! Grrrr!)
    Alternatively check out a reference PCB for the 275 on google and compare it against yours.
  6. Fazed
    Fazed Minimodder
    5 Jul 2009
  7. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Yup, the Palit GTX275 uses a 285 Board, so i would imagine you would need a 285 Block.
  8. Taffy
    23 Apr 2009
    Many thank all , what confused me was the reference to VGA when the Palit card has 2 x Dual link DVI outputs. It appears that both Palit and Gainward use the same card and that there is a good Photo on the EK website of several different waterblocks I shall confirm that the Correct blockfor the Palit is an EK260/275/285
