GTX 280 or HD4870
Discussion in 'Hardware' started by WARHAMSTER, 16 Sep 2008.
  1. WARHAMSTER
    WARHAMSTER New Member
    16 Mar 2008
    Taking the current prices from Scan.co.uk as the example.
    HD4870 -- http://www.scan.co.uk/Product.aspx?WebProductId=831077 £180ish delivered
    or
    GTX280 -- http://www.scan.co.uk/Product.aspx?WebProductId=832699 £255ish delivered
    As you can see the gtx280 has dropped in price recently. Am I mad to by it given I have a 1680x1050 monitor?
    It will replace my X1950XTX and with be kept for at least 18 months. I intend to upgrade to Core i7 with new RAM and mobo (but not monitor, case, hd's etc.) around Xmas.
    Is worth the extra money for a wee bit more future proofing? I intend to pick up Far Cry 2, Crisis Warhead, Fall Out 3 as they come out.
    Got to spend some money before the other half mentions something sensible.;)
    D.
  2. GoodBytes
    20 Jan 2007
  3. moonlight
    moonlight New Member
    7 Jul 2008
    I would like to go with GTX280
  4. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Well, if you upgrade from a X1950XTX either one is a major jump up :lol:
    I don't think you'll notice the difference between GTX280 and HD4870 on a 22" screen. Unless you plan on upgrading your monitor aswell anytime soon, save yourself the cash and buy the HD4870 and some beer :D
  5. sjhujh
    sjhujh Member
    1 Feb 2008
    either would be a good chouice for that res, but i think the extra grunt of the GTX280 will give it better longevity.
    So GTX280 unless you can't afford the extra...
  6. heir flick
    heir flick Active Member
    2 Feb 2007
    im using a 4870 with a 24" monitor and im chuffed to bits with it
  7. Tim S
    Tim S OG
    8 Nov 2001
    I've got a 4870 in my main rig, and I'm loving games @ 1,680 x 1,050 with 8xAA :)
  8. spoon.uk
    spoon.uk Frag Me Bitch!
    1 Sep 2008
    My vote goes to GTX280 ;)
  9. Guest-16
    Guest-16 Guest
  10. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Personally I'd want a GTX280 but that's just because I've been green since the Voodoo.
    The HD4870 would probably be a better bet, for the price and the relatively small real world performance difference, I couldn't in good conscience pay the extra £75 for the nVidia.
  11. WARHAMSTER
    16 Mar 2008
  12. Guest-16
    Guest-16 Guest
    Yes but performance should be about the same difference. ;) There's also a new 260 arriving soon...
  13. phinix
    phinix RIP Waynio...
    28 Apr 2006
    GTX280
    I also have been green since 3dfx:) I say GTX280 or new 55nm GTX280, IF ti comes out.. I sold my GTS512 2 months ago and waiting for a new GTX. For me is like 2 times powerful card (I play at 1920x1200, 24")
  14. Major
    Major Guest
    4870 4tw tbfh imo.
  15. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    qft. :lol:
    Okay, it really is a good card for the price. It runs hot but it has a temp-controlled fan so that basically is ATI's decision.
  16. WARHAMSTER
    16 Mar 2008
    Jeez I'd hate to see your text messages. Probably need MI6 to decode the them.
    WARHAMSTER is ROLLING ON THE FLOOR LAUGHING
    I've ordered the red one BY THE WAY from Amazon for £170 delivered.
    I'll use the money saved for beer and chocolate.
  17. mrbungle
    20 Sep 2004
    its a bit of a no brainer really
    4870 will be mine soon.....
  18. Major
    Major Guest
    4tw gd choice gl + hf wiv 4870. :p
  19. Horizon
    Horizon Dremel Worthy
    30 May 2008
    You do that just to torment people don't you.
  20. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    Well it's not as if people would write like that normally ...:rolleyes:
