Graphics GTX 295 Help please?!?!
Discussion in 'Hardware' started by opi4613, 29 Apr 2009.
  1. opi4613
    opi4613 What's a Dremel?
    27 Apr 2009
    I have a gtx 295, and have a bit of a problem. I have gone on other forums but haven't really got a clear response.
    on windows desktop the graphics card is silent but in games it makes an extremely loud clicking noise. infact really loud. What should I do? Send it back???? Someone on another forum said it could be the chokes??!!?!?
    Any help greatly appreciated :D Infact I love you if you respond and help me. as this is an ongoing very very annoying problem that needs sorting.
    Thanks,
    Billy :D
  2. heir flick
    heir flick Minimodder
    2 Feb 2007
    dosent sound right, i would just send it back
  3. trig
    trig god's little mistake
    10 Aug 2006
    i've seen this problem before with gtx 260's as well. regardless of the response, it is not normal and you should probably rma. i've seen posts saying that it's an issue with the card not receiving enough power. so check your psu ratings and make sure the unit is getting enough. one post said they discussed the issue with an evga rep and he said it was probably "talking capacitors" and that it would not interfere with the cards performance or durability. anyway, i would still rma it.
  4. opi4613
    27 Apr 2009
    Thanks mate,
    I will send it back to novatech.
    :D :D So happy someone has given me a good response.
  5. trig
    10 Aug 2006
    :thumb:
  6. adam_bagpuss
    24 Apr 2009
    ive seen this problem before.
    its something to do with the type of capacitors(or something like that) when voltage is sent through them.
    solid state ones are more expensive and dont make this noise. cheaper ones based on some other design do and its a way for them to cut costs
    IT IS PERFECTLY NORMAL BEHAVIOUR and is not covered under warranty.
    however most of the E-tailers ive seen will replace it at no cost.
  7. opi4613
    27 Apr 2009
    Do you reckon novatech will replace if its about 4 months old.
    Cheers,
    Billy
  8. adam_bagpuss
    24 Apr 2009
    no harm in trying they may do they may not. 4 months is still under warranty so give it a try
  9. opi4613
    27 Apr 2009
    Yeh they should do novatech are normally good. I will go into tonight. Cheers adam .
