Graphics GTX 480
Discussion in 'Hardware' started by Elton, 7 May 2012.
  1. Elton
    23 Jan 2009
    They're on sale for $200 USD today.. Should I pull the trigger?
    I know it'll be a step up from my HD6850 but 570s can be had used for a mere $20 more..
    Also any of you folks know how hot these run in a HAF932?
  2. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    out of the 2 cards id go for the 570 as they will run MUCH quieter and cooler + require a little less power
    aka all round win
    and the cards are usually neck and neck in benches
  3. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Got 2x 480's and they are awesome, They're better than the 570 because they have a more complete memory architecture, and more memory so you get better performance with higher resolutions and more filters applied (which is when you need the performance). If you like you can even make up for the clock differences with a minor bump from software but they don't need it. If power is a concern for you the 570 is still a great card but the 480 is a little better :p
    As for temps older reports said like 90+ C and that isn't true any more, driver improvements have upped performance, and adjusted the fan profile slighty and even with 2 cards in my cramped NZXT M59 they don't go over 88C unless basically you furmark them.
  4. Elton
    23 Jan 2009
    That's the thing I've been wondering. On air I'm not too confident they won't try to burn my ears off.
    To be honest it's just a temporary upgrade as it's actually regressing on generational performance. But Hell, I'd kill for one anyhow.
  5. Madness_3d
    26 Apr 2009
    They're really not as bad as everyone makes out, no louder than my GTX 280 was under load. It's still a top end card with an air cooler so it is audible but it's not a turbine under the desk
    + Silent at Idle
    + Can usually undervolt a chunk at stock clocks if you want to try making it even nicer on the ears (see the 480 appreciation thread)
  6. Elton
    23 Jan 2009
    Hmmm I am now incredibly tempted. Given that it's still nearly 2x the performance of my HD6850..
  7. Teelzebub
    27 Nov 2009
    I've got 3 480's in one rig a 560 in another tbh the 480's aint that loud and the performance is still very good, At the prices you can pick them up at now they are really good value.
  8. Elton
    23 Jan 2009
    Any idea how it does in Multi-monitor applications? I'd loathe to have the Memory @ 100% all the time.
  9. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Under-Volt is the way to go. I'm giving mine a complete test at the moment with 925mV and 700MHz core (stock!) and it's not going over 40 degrees with water cooling. Once I'm satisfied it's 100% stable at 925mV I'll be flashing the BIOS to permanently lower the cards starting and idle voltage to this minimum.
  10. Madness_3d
    26 Apr 2009
    Better than a 570 for sure! That's exactly the kind of situation where memory bandwidth and size is going to matter. 480's can do 2 screens each so if you're talking surround you'll need SLI. for benchmarks of that see here
  11. Elton
    23 Jan 2009
    Soo tempting....
    Decisions decisions..
