Graphics GTX 580 Stickers??
Discussion in 'Hardware' started by roosauce, 1 Apr 2012.
  1. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Hi All,
    This is a bit of a random one ...
    I sold one of my 580s before the 680's came out, and now am ready to sell the other. When I swapped it over with the new 680, I noticed that the sticker had come loose. I tried taking it off, and it has made a gawd awful mess.
    This photo obviously uses the light to significantly highlight the problem, but you get the idea. I don't seem to be able to clean it up.
    This will effect the re-sale value, so I'm wondering if anyone knows where I could get a new sticker that would fit nicely on this card? The card itself works well, so it would be a shame to lose money due to this ...
    Thanks for any tips!
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    A product called 'Goo Gone' is supposed to work quite well.
  3. Teelzebub
    27 Nov 2009
  4. K404
    K404 It IS cold and it IS fast
    11 Sep 2006
    Does it not affect the plastic in any way? :) Could definitely do with something like this in my toolbox
  5. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    Or Isopropyl alcohol, stuff you use to remove thermal compound works fine too
    Edit: Not sure where to get a sticker though :p
  6. Teelzebub
    27 Nov 2009
    No it doesn't affect the plastic at all, I use it all the time on anything I need to remove the gunk left from stickers :thumb:
    This will melt the plastic :nono:
    PingPong likes this.
  7. roosauce
    12 Feb 2010
    Thanks guys - some good ideas for me to get on with!
  8. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    What? When has Isopropyl alcohol ever melted plastic? Yes the ethanol in it is an organic solvent but nowhere near enough to melt plastic. I have wiped several keyboards and other plasticky stuff with Isopropyl alcohol and never had a problem.
  9. Teelzebub
    27 Nov 2009
    Sorry your right just the same the WD40 pen is the best I've tried lots of things and its definitely the best most of these things turn the glue into a sticky blob the WD 40 pen gets it of clean seals up the stickyness
  10. wyx087
    15 Aug 2007
    what brand was it?
    don't see why it would affect reale value, my KFA2 580 is completely blank because i bought it on release week.
  11. roosauce
    12 Feb 2010
    It's Inno 3D. It just either needs to be cleaned up or have a new sticker put on it. Sounds like I will be cleaning it and selling blank.
  12. wyx087
    15 Aug 2007
    Inno 3D isn't a massive brand, so no big loss.
    just clean it to this level of cleanness :)
  13. Maximilian
    Maximilian WC Virgin
    31 Dec 2008
    Alcohol wipe, job done.
  14. Elton
    23 Jan 2009
    Blowdryer/WD4D :D
