Graphics GTX 670 4Gb Superclocked problems
Discussion in 'Hardware' started by Auxilliary, 14 Jan 2014.
  1. Auxilliary
    Auxilliary Crashes into space stations
    27 Jan 2011
    Right so my Graphics card has this problem.
    While gaming it will give strange flashes all over my screen, they almost look like fireworks and in varying colours.
    Now and again it will also give out a blue checkerboard over textures. Every single time it will jump and stutter and eventually either CTD or freeze my whole PC resulting in a hard reset of my whole PC.
    Temperature wise it isnt going above 65 centigrade. The card is also only 9 months old.
    My gut instinct is saying the card is F****d but what do you guys say.
  2. wejjy
    wejjy Minimodder
    9 Aug 2010
    Have had similar issues over the past few weeks, its more than likely linked to driver issues, but which PSU are you using?
  3. mrbungle
    20 Sep 2004
    Its shot.
    Get it RMA'd.
  4. Auxilliary
    27 Jan 2011
    wejjy I am using a XFX 850W Pro
    mrbungle, tis what i thought, strangely though it works just fine when just browsing the internet and watching video...
  5. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Sounds like artefacts to me. Possible cause bad memory or bad solder joints. Back it mate.
  6. Parge
    16 Jul 2010
    Agreed. RMA time.
  7. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    :worried: I have the exact same card but currently have no issues. At least it is EVGA so warranty shouldn't be an issue.
  8. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    It's not being taxed doing these tasks.
    Gaming is going to start putting it under pressure, hence the artefacts.
    RMA for def.
