Graphics GTX 670 SLI vs single GTX 970
Discussion in 'Hardware' started by Kronos, 15 Jan 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    After the crap performance with my SLI set up and Far Cry 4 I am wondering (again) whether to dump SLI and go for one decent GPU as I can see this happing with other games in the future.
    I know that the 670's give a slightly better performance but as I say the issues with FC 4 I wonder whether it is worth keeping them.
    What say you?
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    I say jumping the generations to the 970 will save you money on your leccy bill *and* perform better than your SLid 670s. But having neither available makes that hard to prove...
  3. rollo
    rollo Modder
    16 May 2008
    SLI has always been hit or miss enough with far cry I'd of expected better.
  4. David
    7 Apr 2009
    Twin 670s will be plenty powerful but all you need is poor SLI support for one of your fav games, and you're dropping down to the minimum frame rate of a single 670.
    That's what would tempt me to go for a single GPU instead.
  5. mrbungle
    20 Sep 2004
    You will get say 90-100 each for them, flog em and pick up a faster single card.
  6. acitodg
    acitodg What's a Dremel?
    21 Oct 2014
    Agree with this. I am always a fan of a single faster card than two slower ones in SLI. SLI can be hit or miss sometimes depending on the situation.
  7. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    I followed a similar path swapping over to a single GTX 780 Ti from GTX 670 SLI. Although I couldn't resist for long and bought another GTX 780 Ti! SLI has always worked well for me so I've no regrets.
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    Interesting reading. Thanks.
    And thanks to everyone else, you have pretty much echoed what had been going through my mind. I think that I will need to start saving for a 970.
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    I suppose the next quetion should be which particular flavour of 970?
  11. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    well i have decided on getting the Asus strix version of the 970.
    I started looking at watercooling the 970 but i thought of staying with aircooling for now as its cheaper and the 970 strix is quiet and cool so pointless really.
  12. Kronos
    Kronos Multimodder
    6 Nov 2009
    I think I havw my eye on an Evga. But will start researching tomorrow.
  13. flame696
    15 May 2009
    I have spent all day today researching which card to go for (its given me quite a headache) but i have decided on the strix and will settle for that.
  14. Kronos
    Kronos Multimodder
    6 Nov 2009
    Except that you bought a 290 instead. Most odd change of mind in a couple of hours.
  15. flame696
    15 May 2009
    I bought a 290X, its not that odd i do that quite a lot especially when i think about things i tend to change my mind quite often. This time when i looked at the graphs the 290X did beat or was level with the 970. Then looking at the price difference around £40 i thought i would be crazy not to go for the 290X.
    Knowing me ill probably end up returning it and buying the 970!!!!
  16. Kronos
    Kronos Multimodder
    6 Nov 2009
    Lol yes I suspect you might.
    Think I have settled on this one. http://hexus.net/tech/reviews/graphics/74853-evga-geforce-gtx-970-Cheesecake/?page=2
  17. flame696
    15 May 2009
    I read that a lot of Evga cards had coil whine, I don't know if that's the case now though hopefully someone with an evga card will reply
  18. The_Crapman
    5 Dec 2011
    Evga are releasing a Cheesecake+ very soon, with 6&8 pin pci power connecters, 6+2phase power design over the current 4+2 and comes with a backplate. Although it's fast, mine doesn't like boosting much and I've had to mod the bios to increase the tdp to get decent boost clocks. I think it's hard coded not to go over the 100% power threshold as increasing it to the 110% allowed in ab or precision made no difference.
    Edit: I don't have any noticeable coil whine other than on loading pages where fps goes through the roof.
  19. Kronos
    Kronos Multimodder
    6 Nov 2009
    I do not want to appear rude but could you simplify your last post because this old fogie has no idea what it all means.
  20. The_Crapman
    5 Dec 2011
    Evga are release a new Cheesecake with more power, which should mean it being faster, in the next week or so.
    My Cheesecake is a pig and doesn't get very good clocks and a few other Cheesecake owners have reported similar issues.
    You might want to consider a gigabyte g1 gaming which goes for the same price and seems to be the fastest card out the box, bit some of that will be ye olde silicon lottery.
