Graphics GTX 680 watercooled.. was it worth it for you?
Discussion in 'Hardware' started by feathers, 7 Apr 2012.
  1. feathers
    feathers Minimodder
    11 Apr 2009
    For those of you running liquid cooled 680, was it worth it in terms of overclocking?
    We know the temperature benefits brought by liquid cooling, that doesn't automatically guarantee increased overclock over air though.
    The Zotac 680 I have will OC to 1285 core and 500mhz on vram on air. I generally detest air cooling so in general I would buy a waterblock when one is available. 680 has no problem in that area. EK have the blocks. I could quite happily run my zotac on air without overclock. BF3 on ultra at 1080 seems to run fine. What I need to do is measure the performance increase in game between default 680 speed versus the 1285 + 500mhz I can get overclocked. If the difference is small, why bother OCing? I realise GPU OCing is generally limited compared to CPU but I am evaluating the situation. I would probably get a full cover block purely because I like having low temps but I am interested to hear your experiences and gains running liquid cooled 680?
  2. rollo
    rollo Modder
    16 May 2008
    1400 clock stable and 750 on ram
    Using ek blocks
    400+ above stock guess I got lucky on card
  3. The_Crapman
    The_Crapman Don't phone it's just for fun. Staff
    5 Dec 2011
    Strewth! Did you also oc it on air and if so what was the highest you got?
  4. rollo
    rollo Modder
    16 May 2008
    That was furmark stable 0 artifects
    Enough the cards will be declocked to stock
    Till a game warrants the extra speed
  5. feathers
    feathers Minimodder
    11 Apr 2009
    Which brand?
  6. rollo
    rollo Modder
    16 May 2008
    Due to been in sli could not push on air no was I willing
    Hit 1150 and + 300 on mem that was furmark stable also
  7. rollo
    rollo Modder
    16 May 2008
    Evga feathers don't buy another brand
  8. feathers
    feathers Minimodder
    11 Apr 2009
    Do you mean the furmark that comes with EVGA OC scanner?
  9. feathers
    feathers Minimodder
    11 Apr 2009
    Too late for that. Only 1 shop in the UK had 680 last week and EVGA wasn't in stock.
  10. rollo
    rollo Modder
    16 May 2008
    No furmark as in furmark itself with prime 95 loop also as I stress the entire system
    Did not know evga scanner had a version lol
    For me yes even before overclocking as the temps are 40c under load under water so I'm pretty happy
  11. feathers
    feathers Minimodder
    11 Apr 2009
    Well just a bit concerned cos the EVGA scanner version is crap. I mean it loads the GPU fine (unlike Heaven 3) and shows "artifacts". It doesn't show if your GPU overclock is stable. I had it running for sometime on OC scanner test and showed no artifact errors. Run Heaven 3 or any game and the overclock would crash after some minutes. Problem is Heaven doesn't load the GPU properly. Kombustor does.
    I have gone back to MSI Kombustor in DX11 for testing.
  12. rollo
    rollo Modder
    16 May 2008
    Have played bf3 64 multi for 6 hrs at those settings for actual game testing never been a fan of these benchmarks
    But I'd consider it stable and I still test CPU overclocked in 24 hr
    And my system is still on at those settings now
    Played Diablo 3 beta
    Star wars tor
    Dungeun defenders
    Fable 3
    Crysis 2
    So quiet a wide range of games since I set it up
  13. rollo
    rollo Modder
    16 May 2008
    Does msi combustor support none msi gpus?
    If so I can install and run it
  14. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Yeah it's just a rebranded version of Furmark
  15. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    You don't need waterblocks for the 680's. Obviously they pretty much cut temps in half, but they don't seem to effect overclocking potential and the stock coolers aren't loud.
    Rollo, can you please post some benchmarks with 1400mhz on the core. I'm thinking 3Dmark11, Heaven etc. Cheers.
  16. rollo
    rollo Modder
    16 May 2008
    Sure once I'm home been on phone responding to this topic lol
  17. feathers
    feathers Minimodder
    11 Apr 2009
    I am thinking the same. Have just been playing BF3 64 player 1080 at 1260mhz core + 500mhz vram and I can't really see much difference. I think come the day a GPU overclocks 1ghz+ like a cpu then we will start to see some real improvements.
    On default speed my Zotac is very quiet in game. Not keen on air temps compared to water but nevertheless I question whether there is any significant gain in performance overclocking the 680.
  18. rollo
    rollo Modder
    16 May 2008
    Found a link to somebody hitting 1400 on air lol
    Kingpin forums
    Can't copy and paste on phone
  19. dead beat
    15 Feb 2009
    Yeh, tbh unless you have cash burning a hole in your pocket then I wouldn't recommend it.
  20. dead beat
    15 Feb 2009
    Yeh that's kingpin. I posted the link in another thread.
