Graphics GTX 780 and 770 price drops..
Discussion in 'Hardware' started by AlienwareAndy, 28 Oct 2013.
  1. Harlequin
    Harlequin Modder
    4 Jun 2004
  2. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
  3. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Well given the way that Battlefield 4 is kicking my pc's nuts in, I may have to upgrade my graphics cards next month.
    What do you all make of these as I cannot seem to find a decent review of them.
    http://www.scan.co.uk/products/3gb-...z-gddr5-gpu-993mhz-boost-1046mhz-cores-2304-d
    I may possibly be able to get 2 of them next month, or would it be better to just buy 2 of the normal EVGA cards and then get some waterblocks and backplates for them?
  4. AlienwareAndy
    7 Dec 2009
    That beta was quite frankly shocking.. I ran it and it was just completely broken. For a giggle I blew up a tree and it half disappeared into the road lol. The collision detection was also totally Donald Ducked. I would summise it was from absolutely ages ago really.
    If you're talking 780s then please, wait for the Radeon 290. Not the X, but the vanilla ever so slightly cut down 290. It should achieve a couple of things. 1 - price. It should be £300-£350. 2 - performance, it should be a whisker away from the 290x.
    Whatever happens I think Nvidia are not going to be able to leave their prices 'as is'. Once the 290 hits it's going to slap the 780 right in the face.
    Now Nvidia may do what they always do (leave prices £50 higher because of Physx, better SLI etc. If they do though? well then like the 7970 vs the 680 the AMD card will just be solid win.
    Whatever happens I don't think we are done yet. AMD still have cards to show ;)
  5. law99
    law99 Custom User Title
    24 Sep 2009
    is the 7970 the same pcb design as the 7950? I forget... I have a reference 7950. I should dig out the model of the waterblock later. Perhaps I can replace my 7950 with boost with a 7970 for no good reason.
  6. damien c
    31 Aug 2010
    Well I need to wait till next month anyway to see what money I have, and if I don't have enough next month then I will have to give the money to my grandad or someone to save it, for me so I don't spend it and wait for Maxwell and just add to it each month.
    I will be sticking with Nvidia since I want EVGA cards for my next ones and they don't do AMD cards.
  7. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    Can't fault that brand loyalty, i've been using EVGA for a number of years.
    It's just sad that the ACX is a little too noisy for my needs.
  8. hakank
    hakank What's a Dremel?
    28 Oct 2013
    Some of these prices are really tempting me :D
  9. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I am mightily tempted too! I desperately need some graphics horsepower injected into my aging rig!
  10. docodine
    docodine killed a guy once
    10 Feb 2007
    depends which 7950
    later revisions and higher end models used the 7970 PCB. you can tell by the power connectors, if it's 8pin+6pin pci-e it's got the 7970 pcb.
    law99 likes this.
  11. hakank
    28 Oct 2013
    what games do you most play ?
  12. Sheiken
    Sheiken Wat?
    9 Jan 2005
    GTA V.
  13. GeorgeK
    18 Sep 2010
  14. phinix
    phinix RIP Waynio...
    28 Apr 2006
  15. Elton
    23 Jan 2009
    I've always wondered if they get the cards and the coolers seperately? Because EVGA always have had reference models with lots more HS paste as opposed to other manufacturers.
  16. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I couldn't contain myself any longer!
    Just bit the bullet and ordered an Inno3d GTX 770 "Titan Cooled". It is going to look awesome in my case! The cooler was the deciding factor and I am not the least bit ashamed to admit that!
  17. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Thats the first GTX770 that I've seen with a GTX780/GTX Titan-style shroud on.
    Was wondering where these had got to, would have gone SLI with GTX770's too. :duh:
  18. blueviper11
    blueviper11 What's a Dremel?
    9 Sep 2010
    It go back to £400 now!:waah:
  19. law99
    24 Sep 2009
    bugger. It's two 6pin. Cheers for the tip.
  20. hakank
    28 Oct 2013
    plan to play ;) ?
