Graphics Gtx 970 Cooler swap
Discussion in 'Hardware' started by DIZZY DAZZLER 2010, 2 Feb 2015.
  1. DIZZY DAZZLER 2010
    DIZZY DAZZLER 2010 Tech nut!
    23 Feb 2010
    Guys I fancy a gtx 980 however I need the reference version due to my case (EVGA Hadron), the problem is the reference cards are mega bucks. I currently own a gtx 780 with the smart looking reference cooler and I wondered if I could buy a cheap gtx970 and swap out the coolers.
    Does anyone know if this is at all possible.
  2. TheMadDutchDude
    23 Aug 2013
    Absolutely not. Just look at the two PCBs and you'll soon see how vastly different they are.
  3. DIZZY DAZZLER 2010
    23 Feb 2010
    Cheers Dude
    Just had a look and yes there is a noticeable difference.
    Regards
  4. TheMadDutchDude
    23 Aug 2013
    Sorry to be the bearer of bad news. :D
  5. PocketDemon
    PocketDemon Modder
    3 Jul 2010
    Assuming you're actually talking about either a 970 or 980, are you sure that the reference 980s are really megabucks in comparison?
    Spending literally 2 mins, so i'm not claiming that these are rock bottom prices...
    ...looking at reputable UK suppliers on google shopping, the cheapest non-reference i can see is £419... ...whilst Eclipse have a reference card for £435 delivered.
    in fact i think you can go cheaper than the £419 for a reference card via hardwareversand in Germany, though their pricing varies on payment method so you'd need to double check.
    i've used hardwareversand myself, & imho they're very reliable.
  6. heir flick
    heir flick Minimodder
    2 Feb 2007
  7. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    I imagine a few will show up in the clearance section on ocuk.
  8. heir flick
    2 Feb 2007
    no doubt, im still not sure if im going to keep mine, they are performing great but all the talk of the memory issues is realy putting me off, ive got to the end of feb to make up my mind so just having a good think over it
