GTX 970 System - Low PPD After Rebuild
Discussion in 'bit-tech Folding Team' started by Unicorn, 30 Apr 2016.
  1. Unicorn
    25 Jul 2006
    Yesterday I rebuilt one of my open air dual GTX 970 machines into a 4U rack case. Unfortunately I lost the BIOS profile due to a dead motherboard battery, but I remembered most if not all of the overclock settings and had it back up and running again in no time. I left it on a bench in the comms room folding overnight and came back 24 hours later to check on it and install it into a cabinet, but instead of the ~600k PPD it normally produces, it's now churning out a mere ~120K PPD. Both cards are folding on FahCore_21, one is on 48k PPD and the other at 65k PPD.
    Does anyone know what might be going on here? This has crippled my efforts and I would like to get it running properly again.
    I had attempted to install a third card in the machine, but I didn't have enough PSU cables for my old 1250W Enermax to spread the load across the rails and it refused to boot with all three installed, so I pulled one and put it back into another board for now until I get some connectors from Hong Kong and make up some more PCIE cables.
  2. Unicorn
    25 Jul 2006
    Log files attached:
    Code:
    *********************** Log Started 2016-04-30T14:50:06Z ***********************
    14:50:06:************************* Folding@home Client *************************
    14:50:06:      Website: http://folding.stanford.edu/
    14:50:06:    Copyright: (c) 2009-2014 Stanford University
    14:50:06:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
    14:50:06:         Args:
    14:50:06:       Config: C:/Users/Matt/AppData/Roaming/FAHClient/config.xml
    14:50:06:******************************** Build ********************************
    14:50:06:      Version: 7.4.4
    14:50:06:         Date: Mar 4 2014
    14:50:06:         Time: 20:26:54
    14:50:06:      SVN Rev: 4130
    14:50:06:       Branch: fah/trunk/client
    14:50:06:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
    14:50:06:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
    14:50:06:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
    14:50:06:     Platform: win32 XP
    14:50:06:         Bits: 32
    14:50:06:         Mode: Release
    14:50:06:******************************* System ********************************
    14:50:06:          CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
    14:50:06:       CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
    14:50:06:         CPUs: 8
    14:50:06:       Memory: 3.99GiB
    14:50:06:  Free Memory: 2.49GiB
    14:50:06:      Threads: WINDOWS_THREADS
    14:50:06:   OS Version: 6.2
    14:50:06:  Has Battery: false
    14:50:06:   On Battery: false
    14:50:06:   UTC Offset: 1
    14:50:06:          PID: 5140
    14:50:06:          CWD: C:/Users/Matt/AppData/Roaming/FAHClient
    14:50:06:           OS: Windows 8.1
    14:50:06:      OS Arch: AMD64
    14:50:06:         GPUs: 2
    14:50:06:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 970]
    14:50:06:        GPU 1: NVIDIA:5 GM204 [GeForce GTX 970]
    14:50:06:         CUDA: 5.2
    14:50:06:  CUDA Driver: 8000
    14:50:06:Win32 Service: false
    14:50:06:***********************************************************************
    14:50:06:<config>
    14:50:06:  <!-- Network -->
    14:50:06:  <proxy v='proxy:8080'/>
    14:50:06:  <proxy-pass v='********'/>
    14:50:06:  <proxy-user v='mnesbitt084'/>
    14:50:06:
    14:50:06:  <!-- Slot Control -->
    14:50:06:  <power v='full'/>
    14:50:06:
    14:50:06:  <!-- User Information -->
    14:50:06:  <passkey v='********************************'/>
    14:50:06:  <team v='35947'/>
    14:50:06:  <user v='Unicorn'/>
    14:50:06:
    14:50:06:  <!-- Folding Slots -->
    14:50:06:  <slot id='0' type='CPU'>
    14:50:06:    <cpus v='6'/>
    14:50:06:  </slot>
    14:50:06:  <slot id='1' type='GPU'/>
    14:50:06:  <slot id='2' type='GPU'/>
    14:50:06:</config>
    14:50:06:Trying to access database...
    14:50:06:Successfully acquired database lock
    14:50:06:Enabled folding slot 00: READY cpu:6
    14:50:06:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 970]
    14:50:06:Enabled folding slot 02: READY gpu:1:GM204 [GeForce GTX 970]
    14:50:06:WU03:FS02:Starting
    14:50:06:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Matt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 704 -lifeline 5140 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
    14:50:06:WU03:FS02:Started FahCore on PID 6112
    14:50:07:WU03:FS02:Core PID:6132
    14:50:07:WU03:FS02:FahCore 0x21 started
    14:50:07:WU00:FS00:Starting
    14:50:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Matt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 5140 -checkpoint 15 -np 6
    14:50:07:WU00:FS00:Started FahCore on PID 5172
    14:50:07:WU00:FS00:Core PID:5260
    14:50:07:WU00:FS00:FahCore 0xa4 started
    14:50:07:WU02:FS01:Starting
    14:50:07:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Matt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 5140 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
    14:50:07:WU02:FS01:Started FahCore on PID 5376
    14:50:07:WU03:FS02:0x21:*********************** Log Started 2016-04-30T14:50:07Z ***********************
    14:50:07:WU03:FS02:0x21:Project: 13104 (Run 1, Clone 52, Gen 12)
    14:50:07:WU03:FS02:0x21:Unit: 0x00000008ab436c9056b4f80677272cb2
    14:50:07:WU03:FS02:0x21:CPU: 0x00000000000000000000000000000000
    14:50:07:WU03:FS02:0x21:Machine: 2
    14:50:07:WU03:FS02:0x21:Digital signatures verified
    14:50:07:WU03:FS02:0x21:Folding@home GPU Core21 Folding@home Core
    14:50:07:WU03:FS02:0x21:Version 0.0.17
    14:50:07:WU02:FS01:Core PID:5552
    14:50:07:WU02:FS01:FahCore 0x21 started
    14:50:08:WU00:FS00:0xa4:
    14:50:08:WU00:FS00:0xa4:*------------------------------*
    14:50:08:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
    14:50:08:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
    14:50:08:WU00:FS00:0xa4:Preparing to commence simulation
    14:50:08:WU00:FS00:0xa4:- Looking at optimizations...
    14:50:08:WU00:FS00:0xa4:- Files status OK
    14:50:08:WU00:FS00:0xa4:- Expanded 118523 -> 268860 (decompressed 226.8 percent)
    14:50:08:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=118523 data_size=268860, decompressed_data_size=268860 diff=0
    14:50:08:WU00:FS00:0xa4:- Digital signature verified
    14:50:08:WU00:FS00:0xa4:Project: 6397 (Run 56, Clone 19, Gen 277)
    14:50:08:WU00:FS00:0xa4:Assembly optimizations on if available.
    14:50:08:WU00:FS00:0xa4:Entering M.D.
    14:50:08:WU02:FS01:0x21:*********************** Log Started 2016-04-30T14:50:07Z ***********************
    14:50:08:WU02:FS01:0x21:Project: 9441 (Run 5, Clone 2, Gen 239)
    14:50:08:WU02:FS01:0x21:Unit: 0x00000110ab436c9d56af1b281f22f8e7
    14:50:08:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
    14:50:08:WU02:FS01:0x21:Machine: 1
    14:50:08:WU02:FS01:0x21:Digital signatures verified
    14:50:08:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
    14:50:08:WU02:FS01:0x21:Version 0.0.17
    14:50:10:WU02:FS01:0x21:  Found a checkpoint file
    14:50:10:WU03:FS02:0x21:  Found a checkpoint file
    14:50:13:WU00:FS00:0xa4:Using Gromacs checkpoints
    14:50:13:WU00:FS00:0xa4:Mapping NT from 6 to 6
    14:50:14:WU00:FS00:0xa4:Resuming from checkpoint
    14:50:14:WU00:FS00:0xa4:Verified 00/wudata_01.log
    14:50:14:WU00:FS00:0xa4:Verified 00/wudata_01.trr
    14:50:14:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
    14:50:14:WU00:FS00:0xa4:Verified 00/wudata_01.edr
    14:50:14:WU00:FS00:0xa4:Completed 4584300 out of 5000000 steps  (91%)
    14:50:23:WU02:FS01:0x21:Completed 350000 out of 2500000 steps (14%)
    14:50:23:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
    14:50:31:WU03:FS02:0x21:Completed 560000 out of 2000000 steps (28%)
    14:50:31:WU03:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
    14:51:18:WU00:FS00:0xa4:Completed 4600000 out of 5000000 steps  (92%)
    14:54:00:WU00:FS00:0xa4:Completed 4650000 out of 5000000 steps  (93%)
    14:56:13:WU02:FS01:0x21:Completed 375000 out of 2500000 steps (15%)
    14:56:41:WU00:FS00:0xa4:Completed 4700000 out of 5000000 steps  (94%)
    14:57:56:WU03:FS02:0x21:Completed 580000 out of 2000000 steps (29%)
    14:59:25:WU00:FS00:0xa4:Completed 4750000 out of 5000000 steps  (95%)
    15:02:03:WU02:FS01:0x21:Completed 400000 out of 2500000 steps (16%)
    15:02:06:WU00:FS00:0xa4:Completed 4800000 out of 5000000 steps  (96%)
    15:04:46:WU00:FS00:0xa4:Completed 4850000 out of 5000000 steps  (97%)
    15:05:18:WU03:FS02:0x21:Completed 600000 out of 2000000 steps (30%)
    15:07:27:WU00:FS00:0xa4:Completed 4900000 out of 5000000 steps  (98%)
    15:07:55:WU02:FS01:0x21:Completed 425000 out of 2500000 steps (17%)
    15:10:08:WU00:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
    15:10:09:WU01:FS00:Connecting to 171.67.108.45:8080
    15:10:11:WU01:FS00:Assigned to work server 155.247.166.219
    15:10:11:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.219
    15:10:11:WU01:FS00:Connecting to 155.247.166.219:8080
    15:10:12:WU01:FS00:Downloading 117.26KiB
    15:10:12:WU01:FS00:Download complete
    15:10:12:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:6396 run:66 clone:34 gen:103 core:0xa4 unit:0x000000810002894b5462c8a9a005369f
    15:12:45:WU03:FS02:0x21:Completed 620000 out of 2000000 steps (31%)
    15:12:49:WU00:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
    15:12:49:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
    15:12:59:WU00:FS00:0xa4:
    15:12:59:WU00:FS00:0xa4:Finished Work Unit:
    15:12:59:WU00:FS00:0xa4:- Reading up to 1254528 from "00/wudata_01.trr": Read 1254528
    15:12:59:WU00:FS00:0xa4:trr file hash check passed.
    15:12:59:WU00:FS00:0xa4:- Reading up to 109840 from "00/wudata_01.xtc": Read 109840
    15:12:59:WU00:FS00:0xa4:xtc file hash check passed.
    15:12:59:WU00:FS00:0xa4:edr file hash check passed.
    15:12:59:WU00:FS00:0xa4:logfile size: 88161
    15:12:59:WU00:FS00:0xa4:Leaving Run
    15:13:02:WU00:FS00:0xa4:- Writing 1524429 bytes of core data to disk...
    15:13:02:WU00:FS00:0xa4:Done: 1523917 -> 1289201 (compressed to 84.5 percent)
    15:13:02:WU00:FS00:0xa4:  ... Done.
    15:13:02:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
    15:13:02:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:6397 run:56 clone:19 gen:277 core:0xa4 unit:0x000001560002894b5462c9cd7066f0de
    15:13:02:WU00:FS00:Uploading 1.23MiB to 155.247.166.219
    15:13:02:WU00:FS00:Connecting to 155.247.166.219:8080
    15:13:02:WU01:FS00:Starting
    15:13:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Matt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5140 -checkpoint 15 -np 6
    15:13:02:WU01:F
    S00:Started FahCore on PID 7724
    15:13:03:WU01:FS00:Core PID:7092
    15:13:03:WU01:FS00:FahCore 0xa4 started
    15:13:03:WU01:FS00:0xa4:
    15:13:03:WU01:FS00:0xa4:*------------------------------*
    15:13:03:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
    15:13:03:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
    15:13:03:WU01:FS00:0xa4:Preparing to commence simulation
    15:13:03:WU01:FS00:0xa4:- Looking at optimizations...
    15:13:03:WU01:FS00:0xa4:- Created dyn
    15:13:03:WU01:FS00:0xa4:- Files status OK
    15:13:03:WU01:FS00:0xa4:- Expanded 119558 -> 271752 (decompressed 227.2 percent)
    15:13:03:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=119558 data_size=271752, decompressed_data_size=271752 diff=0
    15:13:03:WU01:FS00:0xa4:- Digital signature verified
    15:13:03:WU01:FS00:0xa4:Project: 6396 (Run 66, Clone 34, Gen 103)
    15:13:03:WU01:FS00:0xa4:Assembly optimizations on if available.
    15:13:03:WU01:FS00:0xa4:Entering M.D.
    15:13:05:WU00:FS00:Upload complete
    15:13:05:WU00:FS00:Server responded WORK_ACK (400)
    15:13:05:WU00:FS00:Final credit estimate, 1817.00 points
    15:13:05:WU00:FS00:Cleaning up
    15:13:09:WU01:FS00:0xa4:Mapping NT from 6 to 6
    15:13:09:WU01:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
    15:13:44:WU02:FS01:0x21:Completed 450000 out of 2500000 steps (18%)
    15:15:49:WU01:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
    15:18:30:WU01:FS00:0xa4:Completed 100000 out of 5000000 steps  (2%)
    15:19:36:WU02:FS01:0x21:Completed 475000 out of 2500000 steps (19%)
    15:20:06:WU03:FS02:0x21:Completed 640000 out of 2000000 steps (32%)
    15:21:11:WU01:FS00:0xa4:Completed 150000 out of 5000000 steps  (3%)
    15:23:55:WU01:FS00:0xa4:Completed 200000 out of 5000000 steps  (4%)
    15:25:28:WU02:FS01:0x21:Completed 500000 out of 2500000 steps (20%)
    15:26:36:WU01:FS00:0xa4:Completed 250000 out of 5000000 steps  (5%)
    15:27:31:WU03:FS02:0x21:Completed 660000 out of 2000000 steps (33%)
    15:29:16:WU01:FS00:0xa4:Completed 300000 out of 5000000 steps  (6%)
    15:31:22:WU02:FS01:0x21:Completed 525000 out of 2500000 steps (21%)
    15:31:57:WU01:FS00:0xa4:Completed 350000 out of 5000000 steps  (7%)
    15:34:37:WU01:FS00:0xa4:Completed 400000 out of 5000000 steps  (8%)
    15:34:54:WU03:FS02:0x21:Completed 680000 out of 2000000 steps (34%)
    15:37:10:WU02:FS01:0x21:Completed 550000 out of 2500000 steps (22%)
    15:37:18:WU01:FS00:0xa4:Completed 450000 out of 5000000 steps  (9%)
    15:39:58:WU01:FS00:0xa4:Completed 500000 out of 5000000 steps  (10%)
    15:42:20:WU03:FS02:0x21:Completed 700000 out of 2000000 steps (35%)
    15:42:38:WU01:FS00:0xa4:Completed 550000 out of 5000000 steps  (11%)
    15:43:03:WU02:FS01:0x21:Completed 575000 out of 2500000 steps (23%)
    15:45:19:WU01:FS00:0xa4:Completed 600000 out of 5000000 steps  (12%)
    15:48:17:WU01:FS00:0xa4:Completed 650000 out of 5000000 steps  (13%)
    15:48:52:WU02:FS01:0x21:Completed 600000 out of 2500000 steps (24%)
    15:49:41:WU03:FS02:0x21:Completed 720000 out of 2000000 steps (36%)
    15:51:26:WU01:FS00:0xa4:Completed 700000 out of 5000000 steps  (14%)
    15:54:10:WU01:FS00:0xa4:Completed 750000 out of 5000000 steps  (15%)
    15:54:48:WU02:FS01:0x21:Completed 625000 out of 2500000 steps (25%)
    15:57:09:WU01:FS00:0xa4:Completed 800000 out of 5000000 steps  (16%)
    15:57:11:WU03:FS02:0x21:Completed 740000 out of 2000000 steps (37%)
    16:00:21:WU01:FS00:0xa4:Completed 850000 out of 5000000 steps  (17%)
    16:00:43:WU02:FS01:0x21:Completed 650000 out of 2500000 steps (26%)
    16:03:31:WU01:FS00:0xa4:Completed 900000 out of 5000000 steps  (18%)
    16:04:27:WU03:FS02:0x21:Completed 760000 out of 2000000 steps (38%)
    16:06:46:WU02:FS01:0x21:Completed 675000 out of 2500000 steps (27%)
    16:06:53:WU01:FS00:0xa4:Completed 950000 out of 5000000 steps  (19%)
    16:10:08:WU01:FS00:0xa4:Completed 1000000 out of 5000000 steps  (20%)
    16:11:59:WU03:FS02:0x21:Completed 780000 out of 2000000 steps (39%)
    16:12:47:WU02:FS01:0x21:Completed 700000 out of 2500000 steps (28%)
    16:13:16:WU01:FS00:0xa4:Completed 1050000 out of 5000000 steps  (21%)
    16:16:11:WU01:FS00:0xa4:Completed 1100000 out of 5000000 steps  (22%)
    16:18:36:WU02:FS01:0x21:Completed 725000 out of 2500000 steps (29%)
    16:19:04:WU01:FS00:0xa4:Completed 1150000 out of 5000000 steps  (23%)
    16:19:11:WU03:FS02:0x21:Completed 800000 out of 2000000 steps (40%)
    16:22:03:WU01:FS00:0xa4:Completed 1200000 out of 5000000 steps  (24%)
    16:24:28:WU02:FS01:0x21:Completed 750000 out of 2500000 steps (30%)
    16:25:25:WU01:FS00:0xa4:Completed 1250000 out of 5000000 steps  (25%)
    16:26:32:WU03:FS02:0x21:Completed 820000 out of 2000000 steps (41%)
    16:28:10:FS00:Paused
    16:28:10:FS01:Paused
    16:28:10:FS02:Paused
    16:28:10:FS00:Shutting core down
    16:28:10:FS01:Shutting core down
    16:28:10:FS02:Shutting core down
    16:28:10:WU03:FS02:0x21:WARNING:Console control signal 1 on PID 6132
    16:28:10:WU03:FS02:0x21:Exiting, please wait. . .
    16:28:10:WU02:FS01:0x21:WARNING:Console control signal 1 on PID 5552
    16:28:10:WU02:FS01:0x21:Exiting, please wait. . .
    16:28:11:WU03:FS02:0x21:Folding@home Core Shutdown: INTERRUPTED
    16:28:11:WU03:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
    16:28:11:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
    16:28:12:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
    16:28:43:Removing old file 'configs/config-20151124-133838.xml'
    16:28:43:Saving configuration to config.xml
    16:28:43:<config>
    16:28:43:  <!-- Network -->
    16:28:43:  <proxy v='proxy:8080'/>
    16:28:43:  <proxy-pass v='********'/>
    16:28:43:  <proxy-user v='mnesbitt084'/>
    16:28:43:
    16:28:43:  <!-- Slot Control -->
    16:28:43:  <power v='full'/>
    16:28:43:
    16:28:43:  <!-- User Information -->
    16:28:43:  <passkey v='********************************'/>
    16:28:43:  <team v='35947'/>
    16:28:43:  <user v='Unicorn'/>
    16:28:43:
    16:28:43:  <!-- Folding Slots -->
    16:28:43:  <slot id='0' type='CPU'>
    16:28:43:    <cpus v='6'/>
    16:28:43:    <paused v='true'/>
    16:28:43:  </slot>
    16:28:43:  <slot id='1' type='GPU'>
    16:28:43:  </slot>
    16:28:43:  <slot id='2' type='GPU'>
    16:28:43:  </slot>
    16:28:43:</config>
  3. Unicorn
    25 Jul 2006
    Cards are not being utilised properly at all, the GPU usage as reported by MSI Afterburner is hovering around the 60-70% mark, whereas my other system's identical GPUs are between 80-90% and sometimes higher. Uninstalling and re-installing display drivers now.
  4. Unicorn
    25 Jul 2006
    Copied from the FoldingForum.org topic on the problem, in case anyone was wondering what solved the issue.
    Splooshiba likes this.
  5. chin913
    chin913 忍び So say we all
    26 Apr 2009
    Well got my gtx 970 going for a few days now and so far so good :)
  6. chin913
    26 Apr 2009
    quick question I have a NVidia 770 would adding that in the same pc fold also or does mixing gpu's a no no ?
  7. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Note sure, as the architecture is different in this case (one being Kepler and the other Maxwell).
    One way to find out ... give it a go :dremel:
  8. chin913
    26 Apr 2009
    Cheers Doc , it's the misses pc atm and I could use that for folding from time to time.Just don't want to add a card that may slow down this system ..Only just assembled it a few days ago and there is no overclock on it yet !
