Graphics GTX280 random red light
Discussion in 'Hardware' started by [PUNK] crompers, 26 Oct 2010.
  1. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    I've had my 280 about 18 months, the PSU about 2 1/2 years.
    Basically my monitors randomly turn themselves of, and the light on the back of the card goes red, I know this means its not getting enough power.
    Its happened three times now and I cant see any correlation:
    once about 5 minutes after playing TF2
    once in the middle of watching a video
    once just now when I was sat browsing the net
    It hadn't happened for a bout a week and a half before just now. It started when I changed my system to i7 about three weeks ago.
    The only solution is to reset the system, I did try cleaning the card out with compressed air.
    So is my card or my PSU on the fritz? Should I even be running the system at the moment? here are my everest values:
  2. Teelzebub
    27 Nov 2009
    I would try another psu, Can you borrow one to test with ??
    Apophis54 likes this.
  3. [PUNK] crompers
    20 May 2008
    see this is the problem, i dont have a spare one unfortunately. also the problem is very intermittent so if i was to borrow one i'd have to have it a good while. plus i cant think of anyone i know who'd have a psu with 8 pin CPU power etc.
    I'm guessing a new psu is the answer here? I cant see anything to suggest its a known issue with the GTX280. Just seems a little strange that it doesn't happen when the card is under load.
  4. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Last time I saw a red light on teh GTX2** series, there a was a video of 3 of them benching Crysis non-stop on an infinite loop, one of the cards cooked itself and the red light came on..
    Could be the PSU, but surely 700w is enough for a GTX280?
  5. [PUNK] crompers
    20 May 2008
    its defo enough, just depends if its dying i guess
  6. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Reseat the card, clean the contacts, is it OCed? if so go back to stock
  7. [PUNK] crompers
    20 May 2008
    how should i clean the contacts? just with a dry (obviously) soft cloth? reseated sunday when i blew it out with compressed air, didnt clean contacts though.
  8. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Maybe try an eraser (or rubber, pfftttt :D) along the card PCI-E contacts? White spirit afterwards to remove any leftover residue.
  9. [PUNK] crompers
    20 May 2008
    will try that tomorrow, annoying thing is i wont know until it red lights again, and i have no way of testing
  10. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    is it possible the PCIE power connector on the card has a dry joint ? Or maybe worked itself lose ?
    could try baking the card
  11. [PUNK] crompers
    20 May 2008
    this keeps happening, just in the middle of COD BO. tried reseating the card several times. not sure what my next step is?
  12. [PUNK] crompers
    20 May 2008
    just happened again whilst watching iplayer
    the card keeps jumping to 100% fan too, i think it could be on the blink
  13. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    keep MSI afterburner up and look at GPU usage?
  14. [PUNK] crompers
    20 May 2008
    i have a desktop gadget that does this, havent noticed anything untoward.
    when i tried using afterburner to change the fan profile the fan would jump to 100% but show 30% in everest ultimate
  15. [PUNK] crompers
    20 May 2008
    This has been happening pretty much since then, still very erratic and there seems to be no correlation between what is running at the time and the crash. Just happened in the middle of a round of BC2 so I'm really peeved now!
    I dont have a PSU to test with, dont have a spare gfx card. In my situation what would you do?
    would it be worth trying a new bios on the card?
