Graphics GTX480 for £160 anyone?
Discussion in 'Hardware' started by Spanky, 18 Aug 2011.
  1. Spanky
    Spanky Minimodder
    14 Apr 2010
  2. Big Elf
    23 Apr 2009
    Any idea who the manufacturer is?
  3. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    If only I had the money, I'd buy 2.
  4. KidMod-Southpaw
    28 Sep 2010
    They're generally OEM nvidia cards which are sold under the retailer brand, they're made in the same factory as the branded cards, so there are no quality issues.
  5. Big Elf
    23 Apr 2009
    I'd be thinking of buying a couple if they're reference cards for water cooling.
  6. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    They will be reference cards, can almost guarantee that
  7. KidMod-Southpaw
    28 Sep 2010
  8. LennyRhys
    LennyRhys Oink!
    16 May 2011
    A small and very expensive upgrade. The 5850 is more-or-less equal to a GTX470 which isn't all that far behind a GTX480, but maybe the extra punch will come in handy for the higher res. £200 is steep though...ouch.
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    For £200, a pair of GTX 460's in SLI would be faster (and probably cooler).
  10. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    True, if I were water cooling I'd go for a 480, though.
  11. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Im water cooling my 480 and the main difference ive found from my 460 is the framerates at higher resolutions. The extra ram on the 480 comes in handy
  12. Spanky
    Spanky Minimodder
    14 Apr 2010
    Yeah i see your point about it not being a massive upgrade, but i will recycle the 5850 on fleabay and will still get reasonable money for it, it has a Zalman 3000 series cooler on so i will sell for sure.
    By the time i have a decent cooler on it and ramp up as much as i can get out of it, it might make the differance in my fps that im looking for. A 570 is still way more expensive than this.
  13. Parge
    16 Jul 2010
    £210 - not that much more expensive...
  14. sirsiddius
    sirsiddius What's a Dremel?
    9 Sep 2010
    That ridicoulously low price makes want to throw something. I bought a gtx 480 last sept for 320gbp.
    Would buy a 2nd one for SLI if I had the forsight to buy a sli compatible mobo and a bigger psu.
    RAGE.
  15. mrbungle
    20 Sep 2004
    Its a decent upgrade, dont listen to all the 480 hate :)
    In most games your minimum frames will take a big jump.
    Sell your 5850 for 80 then you have a decent upgrade for not alot of cash.
  16. LennyRhys
    LennyRhys Oink!
    16 May 2011
    That's almost a year ago... one year is a LONG time in the components market, lol. Plus, I've had SLI twice before and it's totally overrated, so don't kick yourself too hard. :)
    @ mrbungle, there is no 480 hate :p The jump from 5850 to 480 really isn't a big one, even though the 480 is still a very powerful card by today's standards.
  17. facwit
    facwit What's a Dremel?
    24 Aug 2010
    All gone now. Hopefully this means that a general price drop is on the way.
