Graphics Gtx560ti hdmi
Discussion in 'Hardware' started by Darkwisdom, 27 Dec 2011.
  1. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    I got the card in the title for crimbo, happier than larry with the performance, all my games on max.
    Problem is in windows, wording is strange. Some words have strange colours around them, and shadows are fuller, and it's just a bit odd.
    IS this something to do with me using hdmi? Or someone recommend a solution?
  2. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Have you tried dvi? And what monitor do you have?
  3. Darkwisdom
    27 Aug 2011
    Not got a dvi cable. Samsung b2230.
  4. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Well have you checked the display settings? nVidia drivers should auto detect and sort them out. But I would check them.
    And have you checked monitor settings? That could be the cause of the problem.
  5. Darkwisdom
    27 Aug 2011
    I just Sorted it out. IT was the monitor settings.
    It was set to AV rather than PC. It source finds on auto, then customises settings.
    I use a freeview HD box as well, probably the cause.
  6. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Good news dude!!!
