Graphics GTX580 - how hot is hot?
Discussion in 'Hardware' started by mikemorton, 14 Feb 2011.
  1. mikemorton
    mikemorton Minimodder
    5 Nov 2010
    Hi all,
    I have two 580s in SLI running on an i7 920 with a mild 3.2 overclock.
    The case is a Corsair Obsidian with the three stock fans and an additional four.
    Typical temps under load are 29C for the SSD, 30C for the HDD and 50C for the CPU.
    But the GTX 580s run 89C and 88C respectively after extended sessions (two to three hours) of demanding games like Crysis Warhead. :eeek:
    Is this normal for an air-cooled case?
    Should I be worried?
    The GPUs are running at stock speeds.
  2. rollo
    rollo Modder
    16 May 2008
    Your temps are normal
    I get 85 c top card 83c bottem under furmark as reference using 800d case. I've not put them both together though there in slot 1 and 3 instead of 1 and 2
  3. mikemorton
    5 Nov 2010
    Thanks Rollo - that's good to know.
    I don't have room on my mobo to split the cards, so that's probably why they are running a bit hotter being so close together.
  4. russ555
    russ555 What's a Dremel?
    24 Apr 2009
    Not exactly the same situation but I have recently installed a 560 and my cases cooling is pretty poor but it has still never gone above 60c. even playing crysis warhead on max settings.
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    It's because the 800D is more aimed at watercooling than air cooling. if you had a HAF 932 or HAF x then your temps would be different.
    Just watercool them... :p
  6. mikemorton
    5 Nov 2010
    I'd love too - but I'm too scared I'd mess things up!
    I know, what a wuss, eh?
    I know virtually nothing about watercooling - is it possible just to wc the 580s - or would it be better to go the whole hog and do the entire system?
    And what happens when you switch components?
    I'm guessing a new mobo and CPU will be in the case by the end of the year.
  7. Bloody_Pete
    11 Aug 2008
    Have a poke through the thread in my sig :) it'll help getting you started :)
  8. Teelzebub
    27 Nov 2009
    Those temps are about right for your set up it all about air flow I found I removed all the PCI blanking plates and the air flow improved.
  9. russ555
    24 Apr 2009
    Sorry for going off topic but is that download speed in your sig right?:eeek:
  10. Bloody_Pete
    11 Aug 2008
    Oooooooh yes....
  11. KidMod-Southpaw
    28 Sep 2010
    I can never get to sleep at night wondering how the hell you have a speed like that...
    What's your secret? :naughty:
    On topic, it's quite a normal temperature for having two very powerful cards so close together. You could maybe upgrade the stock fans to something that pushes a little more air?
  12. Bloody_Pete
    11 Aug 2008
    Living somewhere with ASk4 internet and the managed switches seem to have screwed up. So when the building is empty, thats what I get... Although they've upgraded it now, so i may max GB Ethernet this summer...
    Teelzebub likes this.
  13. Pete J
    Pete J Employed scum
    28 Sep 2009
    Yeah, those temps are nothing to worry about. The cards will throttle at 97C, which in these terms is quite a way off.
  14. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    Cant you just turn the graphics cards fans up, Have you got the fans on auto at the moment
  15. mikemorton
    5 Nov 2010
    OK, thanks for all your advice guys.
    It looks like I don't need to worry too much then.
    I'll try removing the extra slot covers and see if that reduces temps even further.
    But having read Pete's guide I am very tempted to one day go for watercooling.
    I guess there are three basic ingredients: components, knowledge - and balls of steel :D
  16. wyx087
    15 Aug 2007
    download MSI Afterbuner, and setup a more steeper fan profile curve.
    i've set mine so when gaming, it sits around 70c (with 65% fan, pretty loud, but not as loud as my speakers, so all good). never exceeds 75c.
    and Pete J, your temperature might be limiting your overclock, i've found if i turn fan to maximum (85%), i will be able to get 940MHz out of the card, if not, i can only get maximum of 920MHz, before it crashes 3dmark 11.
  17. Pete J
    28 Sep 2009
    Yeah, I know. If I go to more than 1.05V the top gpu reaches its thermal limit, and tri SLI means that overclocking on stock voltage doesn't go as far as one or two cards. I would watercool them but I don't have the funds for a few months, not to mention I've just had to buy a new mobo and a copy of windows to go with it.
  18. donok
    donok Every Little Helps .....
    16 Feb 2011
    You could buy a heat exhaust. Fits in rear case pci bay and uses a fan to exhaust air out back of case. Cost only Afew quid and could be positioned right under a card.
    Con- look pretty fugly, cheap fan inside
    Worth a afew quid?
  19. wyx087
    15 Aug 2007
    i've got those exhaust, useless for all modern cards because they all vent air out the back anyway.
    it was brilliant for 8800GTX, because it had some vents inside the case, cooking any card under it. with the exhaust sucking those hot air, it cooled the card very well by making sure its surrounding is cool.
  20. donok
    16 Feb 2011
    I see maybe make sure you have enough intake fans.
