Graphics GTX580 in an Antec300?
Discussion in 'Hardware' started by Cleggmeister, 26 Dec 2010.
  1. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Hmmmm, will it fit? Please let me know only it you're sure as I'd like to pull the trigger if it does...
    My HDD drive bays are mostly populated, though I do have a Dremel. Would prefer not to use it though!
  2. murraynt
    murraynt Modder
    6 Jun 2009
    It will fit. Although you will have to move the HDD down near the bottom or the top.
    EDIT: just checked, There is about 11 inches of space.
  3. wyx087
    15 Aug 2007
    should fit, my mate has a 4870x2, which is same size, if not longer, as all the latest long cards.
  4. rollo
    rollo Modder
    16 May 2008
    It will fit not sure on airflow you may need to run those fans pretty hard when gaming.
  5. Fazed
    Fazed Minimodder
    5 Jul 2009
    Very tight fit, couldn't definatively state yes or no.
    However, I had to fit a GTX275 with an AC Accelero xtreme cooler into an Antec 300 a year or so ago and needed to dremel out part off the HDD caddy to shoe horn it in. The total length of that beast was 11.4"
  6. Cleggmeister
    12 Oct 2009
    Thanks folks. I'm sure I can shoehorn it in, temps won't be a problem but noise might. BUT, now I'm seeing HD5870's for £200 I may just go for that instead. I know I'll not get quite the same benchmarks, however for gaming at 1900x1200 I think I'll be fine, with less noise too?
  7. murraynt
    murraynt Modder
    6 Jun 2009
    You can get 570GTX's for 270 ish that would eat the 5870 for breakfast.
    Well worth the day's work IMO.
  8. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    A 5870 won't struggle, it all come down to how much performance you wan't v cost though.
    5870
    6950
    570/6970
  9. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Wont be less noise.
    From Overclock3d's video review on the GTX580 doesn't make much noise.
  10. murraynt
    murraynt Modder
    6 Jun 2009
    Correct, It has a vapor chamber cooler like the Toxic cards. Works very well indeed.
  11. Slizza
    23 Apr 2009
    Was stated that even when overclocked the GTX580 makes less noise than a HD6950/70 at stock speeds.
  12. Cleggmeister
    12 Oct 2009
    Aaah, thanks chaps, I assumed the 580 was noisier...
  13. murraynt
    murraynt Modder
    6 Jun 2009
    Getting it confused with the 480GTX.
