Graphics GTX670 or GTX780 GPU?
Discussion in 'Hardware' started by Kronos, 1 Jan 2014.
  1. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    Is it worth moving from a GTX 670 to a GTX 780? Looking to move to a 30 inch monitor this year and have a chance of getting my hands on a 780 for a very reasonable price.
    But not much point if A), not much of an increase in performance or B), I would be wiser to wait a while to see what new if any GPU's are coming?
  2. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Do it, Glenn.
    I run a 670 on 30" monitor, and it's great, but you have to shave off the very highest detail settings in some games at 1600p (not that it makes all that much difference). The 780 will manage much better and give you more headroom for future titles.
  3. Kronos
    6 Nov 2009
    Cheers Dave.
  4. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    I've got to agree with Dave on this, DO IT!
  5. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    What resolution on the 30" ? I would possibly suggest looking at the 290x (when custom coolers come out) but AMD seems blasphemy around these parts. We talking 780 or 780 ti ?
  6. chewbaccas_nan
    chewbaccas_nan Member
    27 Jun 2011
    When something else comes around that tickles your fancy then sell the 780.
  7. Kronos
    6 Nov 2009
    A 30" monitor is usually around 2560x1600 or 2560x1440, depending on screen ratio, according to Nexxo in another thread And it will be the 780.
  8. MrDomRocks
    MrDomRocks Well-Known Member
    5 Sep 2011
    I would wait till 800 series to be honest. That is what I am doing and saving for that upgrade but that is just me :D
    The Mothership
  9. Cei
    Cei pew pew pew
    22 Mar 2008
    780s are lovely cards, and certainly better at driving the higher resolutions with all the options turned up. 670s seem to struggle, and prefer being at 1080p.
  10. blueviper11
    blueviper11 New Member
    9 Sep 2010
    You right :rock:
    600 series to 700 series not most step up, and you pay round £400? Why not save up a few moths for 800 series .
  11. Nexxo
    Nexxo Stopped treating this country as if it was his own
    23 Oct 2001
    The 780 is prohibitively expensive. Consider the 770 as an almost as good, cheaper alternative.
  12. Kronos
    6 Nov 2009
    Cheers will do but I have had a pretty good offer on a 780.
  13. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    If it gives you more vram than your current 670 it would be a good move... high res loves more vram.
  14. wejjy
    wejjy New Member
    9 Aug 2010
    Im running a Dell 3011 with 680's SLi'd and can run everything at max comfortably, why not pop a second 670 in, you could pick one up cheaply enough, as a temporary measure and then when the 800's are out get that if you see the need? Surely 670's sli'd would outperform a 770??
    Sent from my Nexus 4 using Tapatalk
  15. jinq-sea
    15 Oct 2012
    If space allows, a second 670 would be the cheapest option at the moment. That said, if you're getting a properly good deal on the 780, it's a bit more futureproof and will hold value a little better (most likely) if you want to upgrade now and then again later.
    30" displays like VRAM and GPU resources, so more VRAM and more processing power = win.
  16. mrbungle
    20 Sep 2004
    I picked up a 2nd 670 as it was £125. Pretty much doubled my frames in BF4 and runs well.
    Problem with a single 670 is to get a single card to better it you have to spend £££££££
  17. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    An even better alternative to going down this route would be overclocking the 670.
    The 770 is nothing more than a clock bumped 680. The 670 clock for clock is only marginally slower than a 680.
  18. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I would say - if you can get second 670 in SLI, take it.
    If you dont want to play SLI, then get 780.
    Even if we get 800 series in 3-4 months, it will be expensive, like £500+ for 880.
    Good price for 780 is around £300-320, which if it is in your case, then I would go for it.
    I will be selling my 670 in month or two and be getting a 780. It is good 30-50% performance increase, what I noticed in reviews (will be getting card with ~980-1000MHz)
