GTX690 Faulty
Discussion in 'Hardware' started by Peter187, 6 Jun 2018.
  1. Peter187
    Peter187 What is a Dremel?
    21 Jun 2006
    Hello!
    Just wondering if anyone had any ideas how to get a GTX690 working. It works fine for a while when idling away or watching a movie and will eventually freeze but launching a game will freeze about 2 minutes in. I stripped the card back and cleaned all the dust out and applied new thermal paste
    I bought the card second hand and surprise surprise it doesn't work. If any one knows any tips, tricks or fixes please let me know
    Thanks
  2. TheMadDutchDude
    23 Aug 2013
    Where and when did you buy it?
    The only thing to suggest is to lower clock speeds and see if it still happens.
  3. Zak33
    Zak33 Staff Staff Administrator
    12 Jun 2017
  4. Peter187
    21 Jun 2006
    The card idles under 40 degrees so it's quite cool running both with and without the side cover. I've tested it with 3 PSU's 1x Toughpower 650w, 1x Toughpower 1200w and 1x Corsair RM1000i.
  5. Peter187
    21 Jun 2006
    Only bought it about 2 month ago on Gumtree I will try lowering the clock speeds but maybe the pcb board has a hairline crack
  6. Peter187
    21 Jun 2006
    Well....if anyone buys a GTX690 and having issues like i did use DDU driver cleaner. Can't believe this worked.
  7. spolsh
    spolsh Active Member
    4 Feb 2012
    Nice one, it's always a good idea to use DDU when swapping cards.
    Peter187 likes this.
  8. Peter187
    21 Jun 2006
    Surprised drivers cause this much issue as I've always uninstalled old driver before updating or installing a new card, I was running Assassins Creed Origin for a while and let the card heat up to around 70 degrees no problems but run an old game like GTA 4 and it will crash eventually but i can still get back to the desktop. I let the card run for about 10 hours without freezing up which is good news
