Graphics GTX770 +780 pictured! Titan cooler anyone?
Discussion in 'Hardware' started by jizwizard, 7 May 2013.
  1. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Thought I'd ask as I'd never seen the material being utilised on a GPU cooler and wasn't aware of its properties. Good to know, thanks. :thumb:
  2. chris182
    chris182 What's a Dremel?
    6 May 2011
    I, for one, really like the look of the cooler. Shame underneath it's nothing more exciting than a glorified re-brand!
  3. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    You no longer worried about it melting then. :)
    Years ago I had a Danger Den Acrylic top Maze 4-1 waterblock. The acrylic upper was 3/14 of an inch thick. The block had a TEC below it and the TEC sat on the CPU along with a coldplate (Pentium cpu would idle at -7c and hit 14c full load).
    My water pump plug was disconnected by a niece and the PC was on at the time. I was out of the room and only came upstairs because I could smell something burning (the neoprene insulation and acrylic on the waterblock) The TEC melted and warped the acrylic part of the waterblock. Amazingly my CPU and motherboard were undamaged by this!
  4. Noob?
    18 Oct 2009
    You had put my mind at ease, that and I presumed Nvidia would know its limits.
    However, given your episode, you trying to put me off again? :p
    Amazed by your temps on that block though! Blimey. :jawdrop:
    Thanks. :thumb:
  5. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    I'm interested to see what the 780 brings to the party; I'm itching to upgrade my current card.
  6. Elton
    23 Jan 2009
    I'm curious to see if the cooler layout is the same as my GTX670 and if I can BIOS flash it to the GTX760Ti. :D
    Because if the cooler layout is the same, sod it, I'm going to change that out for the sake of the sexiness. And because I'm a total sucker for shiny metal things.
    (May paint it black though).
    Also, I'm curious if you can SLI the 760Ti and a 670 or a 770 with a 680.
  7. Parge
    16 Jul 2010
    You definitely won't be able to do this.
    That would be awesome, but I can't see the PCB layout being the same, I'd expect the GPU die to be different even if the shader count etc is the same.
    Almost certainly not, in the same way you can't SLI a GTX460 with a 560.
  8. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    I really like the Titan air cooler, it's well made and is actually pretty quiet - It also lights up when the GPU is running; if you like that sort of thing.
    In the couple of days I used the air cooler (before water cooling it) I was impressed with the fact that it was quieter than both the GTX 580 & 680 air coolers.
  9. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I am such a sucker for that cooler as well! I'm guessing I'll never make it fit my gtx 660. Who am I kidding? What's the point :p
  10. Elton
    23 Jan 2009
    I don't know why they'd make a new PCB though. I'd figure they'd be using the original GTX680 PCB instead. Or they would use Titan PCBs given that making one that is entirely different would be a rather expensive use.
    As to the GTX460 point, there is a fundamental die difference though. ;) The GTX560 die is not only bigger but a modified respin. In this case, if rumors are true, the dies are the same (GK104) but the clocks are slightly different.
    Just some thoughts anyhow. I just want that cooler.
