Windows Guess what broke...
Discussion in 'Software' started by hacker 8991, 11 Mar 2004.
  1. hacker 8991
    hacker 8991 What's a Dremel?
    8 Jan 2004
    ... Windows XP!
    OK, I seriously just installed Windows XP Home on to a KP6-BS running two Pentium 2 450MHz with 512MB PC133 RAM and a Diamond Viper V550 16MB AGP (w00t). Anyway, I went through all of Black Viper's Windows tweaks, and then installed AVG Free Edition and ran it. Then, I tried to get the updated drivers for all my hardware, but I just got the V550 drivers instead. Now the problems begin:
    Randomly, Windows XP does the "Countdown to Doom" (say that Winodws must be shut down because of some RPC error or something). This is very annoying, since I have gotten AVG to run three times, and it always finds a "Lovsan" virus, or something similar. I know what you are probably thinking: Oh, it's MSBlaster, just run Windows Update to fix it!
    Yeah. Windows Update is royally screwed, since the one built into Windows doesn't have enough time to download everything before the system gets shut down, and the website is even worse. It tells me that I have an outdated version, then proceedes to download the new one. However, when it is done downloading and installing, it brings me back to the download screen again. Very frustrating.
    So, case in point, does anyone know how to stop random shutdowns in Windows XP Home?
  2. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    type "shutdown -a" in a console :)
  3. hacker 8991
    8 Jan 2004
    Any better ways to solve this problem?
  4. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    reinstall windows
  5. dudeyourmomiscute!
    dudeyourmomiscute! What's a Dremel?
    14 Dec 2003
    switch the rpc options to "take no action" in services under system administration this will stop it and then you can update and get the blaster fix.
  6. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    That was quite uncalled for. What Bruno just gave you was the correct answer to your problems.
    You use the 'shutdown -a' command to stop the Shutdown, then you have time to patch your machine. You will need the KB824146 patch. Once that's done, run the removal tool and reboot. Once that's done you'll not get the shutdown messages anymore.
  7. hacker 8991
    8 Jan 2004
    I could not get those things to download.
    That worked fine, thank you :D
    Does anyone know why the Windows
    Update website is foobar?
  8. Hex
    11 Jan 2002
    The Windows Update site isn't FUBAR. I used it myself last night. I'd guess you have another infection that is preventing you from getting to it.
  9. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    In future if you get an email saying Red Hot Teen Action with a file attached claiming to be a JPG don't open it ;)
    Hex likes this.
  10. Go4t
    Go4t i
    13 Dec 2003
    for future reference google for msblast fix and burn it
  11. hacker 8991
    8 Jan 2004
    eh, it all works now, except windows update
    ill just leave it like it is
  12. kenco_uk
    28 Nov 2003
    If Windows Update doesn't work, try clearing your entire Internet cache (ie6>Tools>Internet Options>Delete Files (Delete all Offline Files). Might work after that, it worked for a computer at work the other day.
    Or for a more precise answer, what you could do is try and run the Windows Update and on that web page is a link to a troubleshooter. Note down the error number it gives (if the update page lets you get that far) and find it on the troubleshooting pages and it should give you an answer that'll hopefully clear your update problem.
    hth
