Windows guide for cleaning up your computer(only xp users!)
Discussion in 'Software' started by galgul, 24 Apr 2005.
  1. galgul
    galgul What's a Dremel?
    23 Apr 2005
    written by gfalgul
    all the responsibility is only on you!
    your computer is too slow? , there are spywares on your computer and u can't remove them?, there are a lot of wrong registry?
    so let's repair all that things!
    first, you have to download that softwares:
    microsoft antispware http://download.microsoft.com/downl...-fca2f2c6f0cc/MicrosoftAntiSpywareInstall.exe
    the second software is MindSoft Utilities XP http://www.shareup.com/free-download.php?id=20206&ref=MindSoft_Utilities_XP-download-20206.html
    and the third is registry mechanic http://www.pctools.com/downloads/rminstall.exe
    let's begin!
    1.go to start->programs->microsoft antispyware->update.
    2.after you updated the program you enter this software.
    3.Do full scan and press like the picture:
    then do like the picture:
    4.please make sure microsoft antispyware is enbale:
    *when you finish the scan please do not touch anything,just press continue.
    part 2
    press pressure right on internet explorer\firefox and then Preferences.
    now clear the cookies, temporary files and history.
    part 3
    1.now we need to use MindSoft Utilities XP,enter this software.
    2.choose your hard driver\s
    3.press next.
    4.choose all the options except of log files:
    the scan take somethis like2 minuites, maybe more and maybe less, it's depending on your number files.
    5.now the software ask if you want to delete that files, choose ok and END.
    part 4
    now enter registry mechanic, run full scan.
    then it's finish press continue:
    we finishted!
    restart your computer.
    written by galgul
  2. advance
    advance What's a Dremel?
    18 Apr 2005
    Thanks, but there are SO many other things you can do to fix it, for example, a GOOD reg cleaner, CCLeaner, etc.
  3. DeX
    DeX Mube Codder
    22 Jul 2002
    Yeah, plus most of us know how to use software so there's no need to go through it step by step. It would be better if you just explained the benefits of using those particular programs and the respective improvements they've made to your system.
  4. SHAKIRALOVER
    SHAKIRALOVER What's a Dremel?
    24 Feb 2005
    Microsoft Antispyware has a clean up built in ,Advanced tools then,Tracks eraser
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    So your tip is download software and run it. :thumb:
  6. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Sorry man, this guide that I wrote covers more, and is better written. Now, if anybody wants to contribute, then please do and I'll add it in and give you credit for it.
  7. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    I think this might of just been someone promoting there software? >_>
  8. ajack
    ajack rox
    17 Apr 2003
    Um...I highly doubt it, unless he works for MS, MindSoft and the other one...
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The MS program impressed me, it found and removed a couple of items AdAware and SpyBot never even spotted (*****ing wrapped files from ThemeXP :grr: ).
  10. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I've used the MS one too a couple of times and found it to be quite good tbh.
    Although I have heard other complain it has a tendency to try and remove non spyware files, something I've not witnessed myself though.
