guilty secret
Discussion in 'General' started by mclean007, 20 Feb 2007.
  1. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Dear All,
    My name is mclean007, and I have a Guilty Secret to share. I have been using adblockplus on my Firefox installation and have for some time neglected to whitelist bit-tech. Today is a special day, for I have seen the light and whitelisted the site. Aren't I virtuous?
    There is a serious side to this post - I actually feel bad about not having done this sooner - bit-tech is a top quality publication and a great community, and if a few cheeky ads here and there will help to support that and to reward those whose hard work makes it all possible, then looking at those ads is the least I can do. I also made the remarkable discovery that, unlike 99% of sites out there, where ads are intrusive, frequently irrelevant and generally irritating, bit-tech's ads are pretty on-target, don't intrude, and blend well with the look and feel of the site. I even saw some ads for some products I might consider buying, so how about that?
    I would urge anyone who uses an ad blocker and who enjoys bit-tech to whitelist the site - it's easy to do and is really only fair. And you never know, maybe you'll see an offer you like.
    Instructions for adblockerplus:
    (1) click the dropdown on the ABP icon
    (2) click preferences...
    (3) click the "add filter" button at the bottom left
    (4) type "@@|*bit-tech.net/" (without the quotes)
    (5) click "okay"
    and you're done! You might need to force refresh the home page to see ads (CTRL-F5). See, they're not that bad, are they?
  2. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    **done**
  3. mushky
    mushky gimme snails
    24 Mar 2003
    click on a few of them while you're at it
  4. pjotero
    pjotero belgian
    2 Jan 2006
    I think they arent payed by the click
  5. Firehed
    15 Feb 2004
    IIRC, they are, but click fraud (yes, that includes senseless clicking on *your* part) helps nobody. By all means, click them, but only if you're actually interested in the product. Don't do it just to try and earn Bit a few bucks, because when advertisers see lower click-through rates, they either pay less per click or advertise elsewhere. Which is bad.
    In any case, I'm glad you've whitelisted Bit. It's one of the only sites that I feel really worth of it, especially since - as you said - the ads are generally on-target and unobtrusive, and the quality of the content certainly justifies putting up with a few ads. I'm glad they added the new shopping section; much more relevant for me, as the geo-targeting of the normal banners seems to be iffy at best (I'll often see ads for UK stores).
    geez... reading through that, it sounds like I work here. Heh, don't I wish :hehe:
  6. cerberus
    cerberus What's a Dremel?
    23 Sep 2003
    Thanks for this I've wondering how to unblock some sites for a while now.
  7. Glider
    Glider /dev/null
    2 Aug 2005
    Or you can off course just right click on adblok in the statusbar and select "whitelist this site"
  8. mclean007
    22 May 2003
    Well, on ABP it's a left click on the dropdown, but yes you can. Only caveat is you will have to separately whitelist www.bit-tech.net, forums.bit-tech.net and shopping.bit-tech.net. My method wildcards it so anything on the bit-tech.net domain is unblocked.
  9. Glider
    Glider /dev/null
    2 Aug 2005
    Not if you select whitelist whole site on the mainpage... all subdomains will be whitelisted too
  10. JinkzUK
    JinkzUK What's a Dremel?
    5 Jan 2004
    Your secret is so dirty, i'm thinking of telling everybody that I 'am' a dwarf with a 8ft penis! IT'S OK!!
  11. mclean007
    22 May 2003
    forums isn't technically a subdomain - it's forums.bit-tech.net, not www.bit-tech.net/forums. Anyway, it didn't work on my copy of adblockplus - I had to add www.bit... and forums.bit... separately, but (because I'm anal about this sort of thing) I manually added the filter instead, as per my instructions above.
    @JinkzUK - there's a market for that kind of thing you know. This time next year, you could be a millionaire! :D
  12. ou7blaze
    ou7blaze sensational.
    5 May 2003
    I don't even block many ads, basically I don't carea bout ads as long as they aren't too obtrusive or make annoying noises even when you haven't moved your cursor over the ad itself.
    The main point that bit-tech has been successful in its implementation of ads is the fact that they are ON TARGET and fit the interests of the people who visit..
  13. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    The only ad I've found annoying on this site has been the S.T.A.L.K.E.R. ads. The flashing is so annoying and I can't always practically scroll it off the edge of the page. :grr: Maybe I should take this to the feedback forum.
