Cooling GV-R695OC-1GD water blocks
Discussion in 'Hardware' started by bluc, 19 May 2012.
  1. bluc
    bluc What's a Dremel?
    4 Apr 2012
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    That's because, EK, at least, don't do waterblocks for that board.
    http://www.coolingconfigurator.com/
    Run through that, it'll simply repeat what I've said, and show you compatible core-only blocks.
  3. bluc
    4 Apr 2012
    Yea have been searching for about a week pretty confident there are non available :-( . When using the gpu only block is it only the video card ram that needs heat sinks? Or are there other parts that need heat sinks as well?
  4. .//TuNdRa
    12 Feb 2011
    GPU ram and the VRM area, that bit with a smaller heatsink on. That converts the 12V in from the power supply down into the lower voltage needed to run the GPU. This, however, creates a crapton of heat, so you'll need a bigger heatsink on that than Gigabyte stock.
  5. bluc
    4 Apr 2012
  6. .//TuNdRa
    12 Feb 2011
    Sadly so. Generally speaking; The Asus DIRECTCUII cards non-reference boards have waterblocks that will fit, but other manufactures tend to vary a bit, so it's a bit of luck of the draw. The best idea would be to look around in your pricerange, then see which cards you can get full cover blocks for.
  7. bluc
    4 Apr 2012
    Yea just a little peeved I did not think of this being a factory oc card I assumed there would be a full cover block I will wait and see how I feel when it comes time to fit the hardware when I finish building the case. Did not want to have to have fans anywhere except on the rads. I will definately have to keep this in mind with future hardware purchases. Cheers and thanks for the help :)
