Scratch Build – Complete GwassGween -FINISHED-Nov13 2013-pics start on page 67
Discussion in 'Project Logs' started by Cheapskate, 25 Jun 2009.
  1. Gunter
    Gunter What's a Dremel?
    14 Feb 2009
    About Nostalgia: It's good to find something special like isnt?
    About the pump concept, I like that one but if you could put 2 or 3 more layers, or you tried and didn't liked?
  2. The boy 4rm oz
    10 Apr 2008
    Fantastic work on the pump top so far.
  3. Cheapskate
    13 May 2007
    Thanks, guys.:D
    @Gunter - OK. I'm not sure what you are asking about the pump.
    The top design I'm going to change to a 1/4" gap between louvers to match the rest of the case. I also need to front shape a bit. The problem I'm having is that the ugly side of the pump will be visible through the front panel. I'm working out a way to mount the fins to some black plastic on that side.
  4. Gunter
    14 Feb 2009
    I was thinking about this two desings, in the first one you could go for 2 our more layers to fit your main idea.
    But your black plastic idea could turn in a perfect way.
  5. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Great Designs! Interesting build, gotta hand it to ya, with the tools you are using and the work that is coming out of it, is pretty awesome. Makes me wonder about the colors I will use in my upcoming build when it comes to plexiglass. I jus wish I could learn all that CAD/Sketchup programming, lol
  6. Cheapskate
    13 May 2007
    Thanks!
    @Gunter - Trust me. The top one will work out nice.:D
    -I'm still a little woozy from gluing. I dropped the syringe in the can. By the time I got it out, I had inhaled way too much. I'm an idiot for not grabbing my mask.
    -I cut the face out of 1/2" stuff.
    -BAM!
    -Then the camera batteries died. I tapped out all the threads during that time. The 1/4" BSPP tap is much easier to use. No more custom fitting with a tapered tap for me.:D
    -I did some quick work with a round bit to open the intake/exhaust holes a bit. Later I cleaned up the intake with a dremel.
    -Here I'm lining up the impeller exhaust for drilling. I go into more detail on this procedure in my guide.
    -Tilted the table and did a test drill...etc.
    -Lots of dremeling, sanding and polish happened. I glued a 1/8" top plate on just a while ago. The hose in the impeller well is an aquarium bubbler. I'm trying to purge the glue out of the hole as gently as I can. Using water made it craze like mad. Someone here has said that rapid cooling is a factor in crazing, so water and alcohol is out.
    Oh, that's NOT purple marker you are seeing this time.:D
    Thanks again to my sponsors!
  7. The boy 4rm oz
    10 Apr 2008
    Dude, great work as always :thumb:.
  8. llH4VOKll
    llH4VOKll What's a Dremel?
    21 Jul 2008
    Amazing work guess we are sponsor buddies lol Thanks Danger Den
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I like the purple.
  10. Cheapskate
    13 May 2007
    Thanks!:D
    @H4vok - Danger Den has been very good to me. They contacted Hardware Labs to get them on board too.
    @perplekks - Good! It's hard to get funky colors over here. I'm hoping this turns out good. It would suck to make a contest prize no one wants.
    There was no crazing this time around. I got the purging method right finally.
  11. Cheapskate
    13 May 2007
    -Gloood the faceplate on. I still have a pinhole seam running from one of the ports along the purple top. I hope I don't have to add a drop of gel glue after getting the guts so pretty.:(
    -I cut out some squares to make fins with. This pic is important because of the pencil line. It's 90 degrees from the edge. Not only was the stuff I got from Eplastics undersize, It's crooked to.
    -Whee! more cutting. This scene has to be boring the hell out of you kiddies by now. I need to add more bananaman. (even EEL won't touch those jokes.:hehe:)
    -One of the fins is a little odd. That's because this is the only one that will be connected to the top.
    -Again? Yawn...
    -All the fins finished. I tried to spell something, but I didn't have a T.
    -Here's where we get groovy.:D
    The mill came with a 3/32" bit, and I finally had a reason to use it. I milled this groove .109" wide to fit the fin.
    -Here's the full groove, and a good shot of the purple-ness to be. I had to remove the masking and the tiny bit of burr on the fin to get it to fit.
    -Success! I can use this trick on the cpx pro housing now.
    -I will confess I did screw up a little. The back groove is off by about 1/64" on one side. This is because I forgot to sand the faceplate flush with the top before I cut it. I didn't think the thickness of the tape would screw me up this badly, but it did.
    Did I mention this was for the MNPCTech Design competition #3? Get in there already!!!
    This update brought to you by my cool sponsors!!
    mvagusta likes this.
  12. perplekks45
    9 May 2004
    Yea, 1/64" is screwed up badly.
    But only by your standards... Awesome work mate! :thumb:
  13. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Being a healthy hetero male I doubt I'd touch anything that contains the words "man" and any mention of his "banana", whether in a literal or figurative sense. :D
    Looks awesome, Cheaps. You can barely tell the deviation, TBH. Especially when it goes in the rig. I think it looks great.
  14. stonedsurd
    11 Mar 2009
    Neat-o!
    I like the purple. But will we need to break out our sunglasses before this is over? I've lost them all over the course of this summer :hehe:
  15. The boy 4rm oz
    10 Apr 2008
    Man you really have a knack at that :thumb:.
  16. jhanlon303
    7 Sep 2006
    Enigma machine code? Hmmm?
  17. Cheapskate
    13 May 2007
    Thanks guys.:D
    @perplekks - It's enough to not fit without more cutting. That equals failure to me.
    @EEL - I said 'bananaman', not 'man banana'!
    @stonedsurd - There will be no purple in this rig. This top is an experiment/prize for the design competition.
    @John - Oh, Shi-You may be on to something! Where's my foil hat?
  18. stonedsurd
    11 Mar 2009
    :duh: HAVE to read more carefully.
  19. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    Wow that is awesome! Great work on the top! I really like your weird and wacky designs, and and i definitely thing that the purple is better than the marker method :thumb:
    :sigh: Im green with envy at your cnc. Me i have a friend with a cnc, and its been 2-3 months that he is still cutting my plastic....im getting it dirt cheap its true, but god this guy wears my patience thin....
  20. Djayness
    Djayness phwupupupup
    7 May 2008
    Hey cheaps is it costly to buy acrylic pieces that thick? I cant seem to find them anywhere?
