Scratch Build – Complete GwassGween -FINISHED-Nov13 2013-pics start on page 67
Discussion in 'Project Logs' started by Cheapskate, 25 Jun 2009.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Cheapstake my friend your work is absolute fantastic and professional! Go on my friend! :)
  2. Cheapskate
    13 May 2007
    :D Thanks, everyone! :D
    @stonedsurd - Join the competition, and you might win this.:naughty: -Who am I kidding... Darkenergy always wins.:hehe:
    @Djayness - 3/4" and 1/2"? I'm getting it from Delvie's Plastics. They would be expensive, but I only bought small sheets. (I only got a 12" square of the 3/4") I have no clue where to get plexi like that where you are.
    Big update...
    -I got the fin glued in place. The solvent didn't get all the way through, but it still looks good. -Oh, the outsides got polished too.
    -What the... Another experiment? I mounted some plastic to a paint stick with wood glue. I need a way to hold tiny parts. I will be making HUNDREDS of spacers like this for the case.
    -The glue worked perfectly, but the masking didn't hold to the part. Right as it was finishing, the bit caught, and the spacer went flying off to I don't know land.
    -Cool! The paper is on there forever. Next time I'll try this with a stronger tape masking.
    -Another experiment. I know of a readily available super-soft grommet material. I was curious to see if I could machine it. YES, that's a toilet tank gasket.:eyebrow:
    -It came out pretty good.
    -I used a NEW ring for this, Honest! Here's the proof!
    -I knew this was a recipe for disaster before I even started... This ring was too soft. The bit touched it and it just jiggled.(EEL, No!)
    -I went back to my old technique of using a sharpened pipe. It didn't work so well either. Later I put them in the drill press and tried to shape them with a trick I learned driving a '70s bigblock.:hehe: I made a lot of rubber dust, and they still looked crappy.
    -Anyway, I got the press out for another reason. I had to use the spacer-making collet TribalOverkill gave me to clean up the parts. A paint tarp went over the valuables.
    -Here's one set cleaned up.
    -Gluing time. I set up everything to fit 6-32 screws for this stage.
    -I glued the first set of spacers on. It was a bad time to find out I had the shakes.:wallbash:
    -As the masking came off, It started sinking in how effing awesome this thing turned out!
    -Even unfinished and with the ugly grommets, it looks sick!
    -I managed to drip and get my finger in it.:(
    Next up, I need to clean up the bo-bos, and polish the impeller well. Then there's the leak test.
    This awesome post was brought to you by awesome sponsors.:D
    stuartwood89, Bad_cancer and Combinho like this.
  3. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    That is gonna look amazing :D
    La carotte d l'o likes this.
  4. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    Awesome post indeed! that is the sickest top ive seen!
    Fantastic! i dunno what to add really... Its just that cool!
  5. Cheapskate
    13 May 2007
    Thanks. -That's where I was at!:hehe: It just hit me when I saw it, and I said "holy cr*p!" really loud. The purple was kinda plain until I shined up the edges, so it caught me by surprise.
    La carotte d l'o and jhanlon303 like this.
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I just peed myself... and not just a little.
    ****IN' HELL MAN! AWESOME! :rock:
  7. jhanlon303
    7 Sep 2006
    Purple is ALWAYS a good color on H2O bits.
    +rep
    john
  8. Combinho
    Combinho Ten kinds of awesome
    5 Aug 2008
    That is looking awesome. :thumb:
  9. Sphering
    Sphering What's a Dremel?
    31 Oct 2006
    How about putting the gasket in the freezer first? Maybe it would be easier to work on.
  10. talladega
    talladega I'm Squidward
    18 Aug 2007
    yummy! i like it.
  11. The boy 4rm oz
    10 Apr 2008
    Now that is one awesome pump :D.
  12. Cheapskate
    13 May 2007
    Thanks again guys.:D
    @perplekks - You must be getting old too.:hehe:
    @Sphering - I thought about that, but I would have to freeze it once for each grommet. It would have taken forever. I'm thinking about using foam next time.
  13. perplekks45
    9 May 2004
    I wasn't LEAKING!!!
    I'm just 25, goddamnit!
  14. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    F*ck me, that looks sweet!
  15. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    +1 This is going to be really awesome mod. Subbed.:thumb:
  16. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Let's make it a threesome with +1. Awesome work, Cheaps!
  17. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
  18. Cheapskate
    13 May 2007
    :lol: Thanks! everyone.
    @perplekks - maybe quit drinking then?:D
    @craig & EEL - NO:hehe: Thanks for the offer.
    -I need to point this out to whoever gets this. The stock DDC mounting brackets have to come off to use this top. I never liked the stock mounts.
    -The leak test went well. It was certainly colorful to look at.:hehe: I realized I can't pressure test the area I was worried about because it's on the intake. I will have to come up with something later for that.
    -Now, back to GwassGween: Tucked away in the design is a 2nd radiator. I had to come up with something that would fit under the power supply. I bought an mcr 240 from Sidewinder for this. Once the paint stink airs out, I'll get to fitting it. I also need to do something about the sides. You might have noticed I'm not big on logos and graphics. One with a GIANT copyright mark will have to go.
    Thanks again to my great sponsors!:D
  19. talladega
    18 Aug 2007
    that pump top looks so cool!
  20. Cheapskate
    13 May 2007
    Thanks.:D I agree.
