Scratch Build – Complete GwassGween -FINISHED-Nov13 2013-pics start on page 67
Discussion in 'Project Logs' started by Cheapskate, 25 Jun 2009.
  1. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Whatever... :p
    Pump is gorgeous though. :thumb:
  2. Sphering
    Sphering What's a Dremel?
    31 Oct 2006
    Yeah forgot to compliment your great skills earlier. That pump looks really good.
  3. gabriel_d7
    gabriel_d7 Budget Mod?
    21 Sep 2009
    Killer tools.
    Killer skillz.
    Great work from a killer modder.
  4. Cheapskate
    13 May 2007
    Thanks, dudes!:D
    @gabriel_d7 - How did you know I've killed tools?:worried:
    woody_294 likes this.
  5. Cheapskate
    13 May 2007
    2 steps forward, 3 steps back time again...
    :duh:
    -OK... I cut the hole for the 2nd radiator.
    -Everything fits.
    -Now here's where the full scope of my psu screwup finally sinks in. The SR1 360 radiator and the 240 should sit in line with each other, and the PSU draws air through one of the 240 holes...
    -Only my dyslexic *ss not only flipped the PSU template, but the entire layout. The PSU should be over the radiator.
    A re-design is out of the question. The mounts for the radiator and harddrive cage clash with each other like this. If I flip the panel to match the PSU, I am against the motherboard tray.
    Also the swapped layout destroys the placement of the wiring duct.
    My options are to start over, or chop the panel. Both suck.:wallbash:
    Thanks again to my sponsors. They are the only ray of light in this dark post.
  6. charles_h
    charles_h I can has RotoZip?
    14 May 2008
    but with you they're dance steps which means surely you'll be moving forward very soon. :)
    what happened cheaps?
  7. Cheapskate
    13 May 2007
    You post too fast.:D I hit enter and it posted before I was finished. I'm fighting ad banner lag too.:(
  8. charles_h
    14 May 2008
    I frequently do the same when responding to emails...
    Oh man Cheaps... I'm sorry to hear of your discovery. :(
    Surely a day's break and a fresh perspective will do the trick. If I were a betting man, I'd not only say you'll figure it out, but the result will add to the project!
    H2O and Bad_cancer like this.
  9. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
  10. Attila
    Attila still thinking....
    22 Feb 2008
    That's bad luck cheaps. I too have made some colossal F***ups, The PSU cover and
    central spine, the back plate, I just finished cutting and filing the mobo cover and the
    very first bend was in the wrong direction :duh: The bottom line is, if you can fix it
    and you don't have a little voice always nagging at you :hehe:, good.
    Otherwise it's best to bite the bullet and start over.
  11. Cheapskate
    13 May 2007
    Thanks.
    I will chop and flip the top section. I think I can add a bit of 1/4" to fill in the lost material and make it double as a support for the inner baffle.
  12. The boy 4rm oz
    10 Apr 2008
    Damn that sucks mate :(.
  13. Cheapskate
    13 May 2007
    :D I'm used to it at this point. I make the craziest mistakes bouncing between too many projects at once.
    -I pulled the drill out for some countersinks 'n stuff. Don't you hate it when you find out you can't reach all the holes.
    -I drew guide circles to keep me from boring too deep with the hand drill.
    -I finished up the pump top today. I had to drill out the mounting holes to fit 8-32 screws. The bit screamed while boring this one. That was new... Not very pleasant, either.
    -I tapped out the top part. I found a new 'tap wrench' the other day.:D
    -OK... Here's the instruction manual for whoever gets this... The screws go through the bottom with some foam grommets between the case and this part. (I gotta buy some longer screws for this thing...)
    -Then add rubber grommets to the screws... (The ones in the pic are foam, and are a little too thin. You are stuck with the ugly rubber ones I made earlier.)
    -Then you add the pump, then another set of grommets, then screw the top piece on. I'm supplying stainless steel screws, and you should be able to cut them so they don't stick out easily.
    -A face on shot to show various imperfections. I should have cleaned this sucker first. There's still polish residue and oil everywhere.
    -Underside shot shows some nice color transition of the layers, and polish residue in the intake. I'll get that out later.:D
    -Here's a shot with some barbs and 3/8"OD Tygon. You can see the foam isn't thick enough here, and the fins touch the tube because of that.
    OK, I'm going to go tell the MNPCTech design competition #3 that this is part of the prize pool.
    In the mean time, visit my sponsors.:D
    Fisher. and H2O like this.
  14. The boy 4rm oz
    10 Apr 2008
    Sexy sexy pump, one of the best DDC's of all time, OF ALL TIME lol.
  15. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    I concur oz, that is the best freakin' pump top I've ever seen :)
    *Edit* +rep
  16. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    Looking awesome so far, Cheaps!
    Also, sig'd:
  17. Cheapskate
    13 May 2007
    :lol: Thanks!
    @Fisher - Aww, I didn't think it could be taken that way.:wallbash: Where did you even find the quote from John?!?!?
    You better pray no one goes through every thing you said, quotes it randomly out of context, and creates an uber-gay statement.
  18. jhanlon303
    7 Sep 2006
    Or you could drop bits of wisdom like a bread crumb trail for others to follow. Words within words - plans within plans.:D
  19. Fisher.
    21 Jan 2009
    In the "first post" thread. I left the post links in so people would know I wasn't making these up :D
    It actually happened more by accident, but I must say it worked out quite well! :hehe:
    Bring it on, Cheaps! Do your worst! It's the internet, nothing is sacred here! :lol:
  20. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Very interesting project. Subbed!
