Scratch Build – Complete GwassGween -FINISHED-Nov13 2013-pics start on page 67
Discussion in 'Project Logs' started by Cheapskate, 25 Jun 2009.
  1. Cheapskate
    13 May 2007
    :lol: Like I couldn't just run into the modding section and post, "SketchupModdingContestNumberSevenGO!!!"
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    Wowzers :D good to see you back at it though mate :clap:.
  3. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I agree. All contest are off for Cheaps until this gets done. There is too much coolness here to waste away on a shelf.
  4. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    I'm not buying it.... you could do "X" number of SU contests, Modmen 12 and counting and still wake up with another build, while contemplating what your going to do next with Bloo Balls. Oh that didn't sound right!
  5. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Attic Squirrel?????
  6. Cheapskate
    13 May 2007
    Thanks, Guys!:D
    @Voigts - It won't stop me from getting distracted. I have one penciled in for fall, and a tree fell on my Aunt's house last week.
    @Nutman - They are like little buzzsaws here.:duh:
    @LooseNeutral - :lol: I should have named this project after a condition too.
  7. GCOFIELDD
    GCOFIELDD Minimodder
    10 Oct 2010
    Hey Cheaps is that a Sherline CNC Mill?
    I was wondering what had happended to this build--good to see you back at it:dremel::clap:
  8. Nutman
    21 Oct 2008
    So, they're like pests? Have to call in an exterminator?
  9. Cheapskate
    13 May 2007
    @GCOFIELDD - It's a Taig/Deepgroove1. -sturdier, cheaper, more travel.:D
    @Nutman - A guy down the street was catching them and setting them free across the lake. He caught something like 75 in a two month period. I'm thinking about breeding owls...
  10. Nutman
    21 Oct 2008
    Now... and for a danish guy: please explain the term "Breeding owls".
  11. Cheapskate
    13 May 2007
    :lol: -Maybe "keep owls as pets" works better. I don't want to know what a translation error makes it sound like I'm doing with owls...
    -Cut the 2x120 cover, BTW.
    Edit:
    -I've been mulling over what to do with the motherboard cover for years. -I can finally say that without it being an exaggeration. I decided the only way I would get anything done on it was if I committed to a mounting hole pattern.
    -Drilled into the board like it was an owl.:p Here I've just countersunk everything.
    -While I had the press out, I had some new risers that needed sanding.
    -Here's a set polished. I tried a dark grey/light grey/green gradient.
    -The mill space is getting skanky. Time to change some diapers.
    -I snapped this pic before I had all the fins cut. It's a neat pattern.
    -Test fit in the case...
    -I'll have to glue these two panels together while it's bolted to the radiator. The form-factor measurements and the finished product don't jive too well.
    -Here's a rough test fit right after gluing the fan cover together.
    -Another angle. Next up is a lot of sanding. I'm still sanding the grill from the previous post too.
    That's it for this week. Thanks again to my sponsors and everyone else who has supported me this past year.
  12. Cheapskate
    13 May 2007
    :lol: Ninja update backfired on me.
    -I had a feeling when I designed this that I would need something to align the fins. After polishing the underside, they were extremely wonky.
    -I milled out this little comb to fix that problem.
    -While I was at it, I cut some extensions for the underside. I chopped a 45 degree bevel into them to match the sides of the SR1.
    -Here's the gluing setup. A handy optical drive squared up the back edges.
    -One of them decided to slip and I didn't notice until it was too late.:duh: You can see the extension on the underside here too.
    -Alright, then. That's one down. The 2nd grill still needs the fins sanded. Maybe I should put on some black clothes so I'm subconsciously compelled to wet sand.
    Thanks again to:
  13. Evenge
    Evenge Minimodder
    16 Sep 2006
    Ok now I should punish myself for not noticing this masterpiece until just now. Great work Cheaps! :thumb: Stuff like this makes me wana try plastic work also. Oh well, I'll try to keep myself busy with aluminum for now :D
  14. Attila
    Attila still thinking....
    22 Feb 2008
    Not me! I hate working with the stuff, though I love the look of it.
    I got confused with the first pic of your last update. It looks as though the base is curved. :eeek: All the parts are looking good, I'm interested in seeing them together. :D
  15. LooseNeutral
    13 May 2010
    W0W! MORE! don't let a little slip hold this back. Press on man, press on I say :D
  16. The boy 4rm oz
    10 Apr 2008
    The grill looks awesome cheaps :thumb:.
  17. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    U and detail, love how you work with acrylic. simply amazing
  18. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    "Opdrætte ugler". Formentlig til at fange de egeren han har på loftet.....;)
  19. Cheapskate
    13 May 2007
    Thanks.:D
    @looseneutral - The little slip is about 1/32 of an inch. It's just enough to drive me crazy, but invisible at a distance.
    @Bullitdodger - You take all the fun out of it.:lol:
  20. Nutman
    21 Oct 2008
    LOL, quite an insult. Luckily, it's in code! ;)
    Cheaps, great work in the grill - sad about one of them slipping. Bet you're already making a new one, being the perfectionist that you *REALLY* are? ;)
