Scratch Build – Complete GwassGween -FINISHED-Nov13 2013-pics start on page 67
Discussion in 'Project Logs' started by Cheapskate, 25 Jun 2009.
  1. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Nice work, cheaps
  2. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Cheaps celebrating.
  3. Cheapskate
    13 May 2007
    @Mankz - It happens. Don't pretend it's something new.:D
    @Krunchr - Thanks.
    @Barry - Yeah, Like that. -Maybe with less hip work and poor rhythm. In fact, it was probably more like those in-chair geriatric exercise shows PBS used to air...
  4. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    nice progress cheaps! that's why i never dare to start a buildlog, it would take atlest five years or something... >.<
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    Update from cheaps with victory dances, awesome progress in the right direction. :D
    Nice block of delrin & side dip of copper on the aluminium cracker. :)
  6. DEFCON Emy
    DEFCON Emy The Emy Charger
    16 Nov 2007
    Incredible work you are a true master ... ... ...
  7. Cheapskate
    13 May 2007
    Thanks.:D
    @Emy -
    What did you censor out? :hehe:
  8. KrunchR
    22 Apr 2008
    I think we all know.
    Lol:D
  9. Cheapskate
    13 May 2007
    -For the next step I needed to make a 'motherboard.'
    -With this I could work out where the cover would be... For the ninth time. I've learned not to trust numbers I wrote down a year ago.
    -The tile saw gave me a chance to chop up the screwed up bits of plastic into tiny cubes. She can't cut perfectly square anymore, so I had to mill a side square to the bottom. I marked the heck out of them to know what edge to glue. It also helps you see what you are cutting. I just kept milling until there was no more red.
    -While I was at it, I made a set of corner brackets. One of the mounting holes is in an odd spot.
    -I glued the corners together with help from a chunk of angle aluminum.
    -Next I glued the mounting blocks on. I then put everything in the case and traced the screw holes.
    -The angle bracket was used here to hold the single plate vertical. It was bound to happen; rocks are starting to bleed into my project pics.:lol:
    -Here's a crappy pic of me using a fitting to get the drilling level.
    -All that stuff got tapped and fit.
    -Next I glued the lid mounting brackets on. I used some 1/8" aluminum to make them inset. The strips in the pic are now glued to the inside of the cover lid near the edges.
    -They still need a little trimming, but they work. I will need to pull the real motherboard to do the rest of the fitting.
    -To finish up: another impulse purchase. I thought this would work perfectly for the bends I need on the ducting. It even has a lip that can be used to hold the edge square. I forgot I will need straight sections, though. :duh:
    Thanks again to my sponsors.:D
  10. Cheapskate
    13 May 2007
    OK, On to bending jig plan B:
    -I started out with some "precision" cut lumber, poster board, glue, and a lot of lead shot.
    -Plaster is really easy to find in my garage, and I have some I need to get rid of. This is my mixing buddy. It makes perfect plaster every time, and can whip up some fluffy pancakes too.
    -The mold bowed a bit, but that's an easy fix. I've been smoothing plaster for ages.
    -I got the cover panels fit and the mounting holes done. Here I'm countersinking. -Note to self in pic. This will be an area that needs consistent countersinks.
    -Once mounted, I took a file to the edges to get them even. I covered the top of the file with electrical tape to prevent scratching.
    -I had to pull the motherboard again for fitting. Worse, I had to pull mobo and GPU as one part this time.
    -Since I screwed up the GPU I/O mount, the backplate needs to come off. I finally found a use for one of those keychain sized crescent wrenches.
    -There's an old PSU I've kept around for it's heavy-duty chromed casing. It's the same gauge as the metal in the GPU backplate.:D
    -I only have the start of a new backplate so far. The garage is too fecking hot to finish it right now.
    -I nailed the hose exit point perfectly somehow. I think it was 60% luck, 50% guess, and 40% elves working while I slept.
    -To get the position of the manifold, I mounted the plate loosely with long screws, and traced it on the underside.
    -I really could have used those elves to get in there...
    -A few filing sessions in, I had this. There's a green line traced where I still need to file some spots.
    -I have to come up with a GPU cover that can be easily removed from the case. Take a picture to commemorate this moment. Cheapskate resorted to using a cardboard mockup! :jawdrop:
    -I ripped out the parts for the cover's main body pretty fast. I was freaking out a bit that the scraps laying around were exactly the size I needed to cut these parts, then I remembered the elves.
    -I finished up that session by milling vents for the memory. 'Nanaman says Hi.
    -I'm currently working out a "hood ornament" for the GPU cover. The elves have already mounted plastic billet for the cutting session, so it's up to me to get a model drawn up.
    I also have to rig up something so I can mill some edges at funny angles. If I put it off for a bit, maybe the elves will cobble something together.
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe:
    Good progress & nice bending jig idea nice smooth curve from that I expect. :clap:
    PSU came in handy too. :)
  12. barry99705
    20 Apr 2008
    Fisherman's lure installer?
  13. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Love your crazy skills Cheaps, and thank goodness for elves. :)
    Nanaman is going ride that duck :lol:
  14. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Why do I see fat pigeon cut-out?! :worried:
    Looking damn good Cheaps! :thumb:
    Edit: Craig - It's a fat pigeon! (Sorry I didn't see your post!)
  15. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    true originality as always.... I look forward to seeing this when it's finished...
    "will the real Mod Munky from Texas, please take the witness stand.... ..."
  16. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    I hope the MOSFET block i make for my UD5 turns out half that nice :)
  17. Cheapskate
    13 May 2007
    :lol: Thanks.
    I wouldn't call it a duck/pigeon. It will have a hose going its bill and another going out its butt soon.
    @Furball - You will need the backplate. Someone else figured out the board warps without it and loses contact in the middle.
    @Barry - what?:lol:
    @Waynio - I can smash it up and start over too. I've been using plaster forever. Somewhere in the city of Houston, someone has a perfect pattern of the Virgin of Guadalupe on their bathroom ceiling in plaster texture. I'm just waiting for them to find it.:D
    @Bill - Me too. By the way, How's the res core?:worried:
  18. Furball Zen
    25 Jan 2012
    Yea i was really disappointed in the difference in thickness between it and my DFI 790FX
  19. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Insane entertainment, or entertaining the insane! Great stuff man :)
  20. Cheapskate
    13 May 2007
    Since I also entertain myself... both.:D
