Case Mod - In Progress Gymkhana Mod / COMPLETED!!!
Discussion in 'Project Logs' started by Moddingboy, 5 Aug 2011.
  1. keir
    keir S p i t F i r e
    5 Oct 2003
    looks good so far, get some details on the carbon fibre bits though.
  2. outsider
    outsider New Member
    12 Jul 2009
    Hi Moddingboy! So this is the mod you mentioned at CM chat? Nice work, It looks cool, I can't wait to see it finished.
  3. awok3N
    awok3N Who dares wins.
    18 Jul 2011
    Love the logo, hate the taste of the drink. Nice cuts, def gonna be good!
  4. Moddingboy
    Moddingboy New Member
    19 Jul 2011
    Thanks everyone! :)
    MrP - I was thinking about the 3M Di-Noc Carbon (Black) vinyl but it's more expensive than the printed one and that was out of stock at my 'dealer'.
    outsider - Yes I mentioned this mod. ;)
  5. Moddingboy
    19 Jul 2011
    -WORKFLOW-
    Day 16: 2011-08-04 / Task: Installing switches
    The big red one for the power, the little red for the reastart. One toggle for the interior lighting and one for the monster logo. The green LED is for the power, the red is for the HDD.
    Day 17: 2011-08-06 / Task: Monster fan grill
    The day whaen I made a Monster fangrill for the rear 90mm fan. The designed shape was cutted out from vinyl and I stich it to a 1mm aluminium piece. Few raw cutting then hours of filing. ~9 hours of work. :dremel:
    The grill will be painted to glossy black and It will get a green vinyl to the center.
  6. chomps1891
    chomps1891 New Member
    11 Mar 2011
    Cant See The Pics Chief
    That was weird Can now
  7. Moddingboy
    19 Jul 2011
    chomps1891 - Please don't quote pictures! Edit pls your comment (Thank you!) ;)
    If you can't see the photos, look at my Picasa Gallery---> http://bit.ly/GymkhanaMod
  8. KiiYzOo
    KiiYzOo New Member
    11 Mar 2011
    awesome work m8 :D :rock:
  9. Watchtown
    Watchtown New Member
    2 Mar 2010
    young blood? dosent matter, nice logo cutout, looking forward to see more of your work
    "all you need is a dremel":clap:
  10. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    i like the way you took a cheap case and battered it into shape
  11. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Suuuuuubbed!
  12. Moddingboy
    19 Jul 2011
    Thanks Guys the positive words! ;)
    The continue is coming now... :clap: :dremel:
  13. Moddingboy
    19 Jul 2011
    -WORKFLOW-
    Day 18: 2011-08-11 / Task: HDD cooling
    As you can see more of the half part of the bottom of the HDD is covered (what a long sentence). There is air what isn't moving at all and it makes the HDD hot. I thought about cutting a hole to the metal covering but after made it the result wasn't as nice as I waited. Something was missing..
    Good for me because I didn't throw away the stock grille from the front. I cutted a piece of this grille and I put to the cutted out ventillation hole. On the pictures you see I had to use some rubber wedge-thing for the mounting.
    The final result is nice and the temperature of the HDD is lower now. I hope you like it. ;)
    Waynio likes this.
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    Very nice modding Moddingboy :dremel::clap: & I loved the video at the begining :rock::D.
    Subbed + 5 stars +rep :)
    Moddingboy likes this.
  15. Moddingboy
    19 Jul 2011
    Waynio - Thank you for the support! :clap: I am very appreciated. ;)
  16. Moddingboy
    19 Jul 2011
    -WORKFLOW-
    Day 19: 2011-08-12 / Task: Installing fan holder
    Today I installed the holder for the 120mm fan. I fixed with poprivets and then filled with putty from the inside. I hope it will looks like an original 12cm fan mount when the paintjob is done. Sadly when I worked with putty there appears some holes.. I drilled them to larger diameter and then putty them out.
    The chassis is done! Tomorrow I'll go to the painter and we breath life and brings colors to the Gymkhana Mod! :clap:
  17. enormous
    enormous New Member
    28 Apr 2010
    Subbed.. for those nice cuts.. and monstah :) +rep
  18. Razarach
    Razarach Member
    28 Jan 2009
    Nice work m8 ;)
  19. RedManc
    RedManc New Member
    30 Jul 2011
    cracking inspriation for the mod hopefully you can carry it off although im sure you will!!
  20. bagman
    bagman Well-Known Member
    18 Apr 2009
    Great work, turning out really well.
