Case Mod - In Progress Gymkhana Mod II - Update: 02.04.13 - Final Pictures!
Discussion in 'Project Logs' started by Moddingboy, 21 Aug 2012.
  1. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    I rather use the darkened plexi than the clear version.:thumb:
  2. jones-965
    jones-965 Modding & tuning
    13 Jul 2011
    Congratulations my friend! Your work is fantastic!
  3. Moddingboy
    Moddingboy What's a Dremel?
    19 Jul 2011
    Thank you my friends! ;)
    I upload the photos to Imageshack. If you have problems with loading them please watch the photo gallery here: Picasa
  4. Matt's_Mods
    Matt's_Mods What's a Dremel?
    23 Nov 2012
    That looks great mate how long did i t take you to cut out your grille ?
  5. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    What's the problem? Why don't you make direct link to these pictures like you did before?
  6. Moddingboy
    19 Jul 2011
    Matt's_Mods - It takes about 25 hours - with the smallest filer I have - to do the best work at detais.
    Here are some little updates;
    This week I get the support package from Kingston Technology. 2x90Gb HyperX 3K SSDs and 2x4Gb HyperX Beast memory modules. :clap:
    Next week I'll continue the building of the SSD holder ( I started to work on) and will do thing about the coverplate in top of the PSU section. :dremel:
    When everything goes right they will be finished next week.
    Yesterday I was very happy because my stuff arrived from MDPC-X. So there will be some sleeving soon. :)
  7. Zsolt Guriga
    Zsolt Guriga What's a Dremel?
    20 May 2012
    incredible how good looks your work,well done my friend
  8. omgdec
    omgdec Minimodder
    29 Oct 2010
    The mouse looks fantastic, going by that.. this gonna be good!
  9. Moddingboy
    19 Jul 2011
    Zsolt Guriga, omgdec - Thanks guys! ;)
    -WORKFLOW-
    Day 8: 2012.11.27. / Task: To do removing default fan grills
    I removed all the case fan's safety grilles to improve airflow. The same will happen to the PSU. There will be only the dust filter in the way of fresh air.
    Day 9: 2012.11.28. / Task: SSD mounting frame
    The Kingston Technology supports my project with two 90Gb HyperX 3K SSDs and my task is to make a mounting frame to these SSDs.
    I used 1,5mm thick aluminum sheets. After some precise cuts I folded them to perfectly match from the mainboard-tray to the front of the case.
    I didn't make the finished item yet but here are some photos of the process;
    Day 10: 2012.12.10. / Task: SSD mounting frame pt.2
    After a little break I have free time to do a little modding. So I continued the SSD frame.
    Day 11: 2012.12.13. / Task: SSD holder frame #3
    This day was for the SSD frame too. It will be 3 pieces together. Previously I did the first part then I made the second and third pieces today. The smallest part will be in the center of the frame and It will be the real holder of the SSDs. I attach plexiglass rods to this part. These plexiglass bars created with multitool (as you can see in the pictures). These little plexis and the metal parts will be glued together with epoxy.
    In the end I drilled holes to install the SSDs. Finished photos of the frame soon. :)
    Day 12: 2012.12.14. / Task: PSU coverplate
    I made the cover for the PSU and the hider of the sleevings. It is a 1.5mm thick aluminum sheet cutted then folded to exactly fit on the plexirod frameing. These plexi pieces were cutted with laser after precise calculations and designing to fit tightly and be a tough skeleton to the coverplate.
    Day 13: 2012.12.20. / Task: ODD coverplate
    Sadly the previously showed plexiglas framing was happened to be weak because it cracked. So it get a bit modificated - need some reinforcements on the weak points. While waiting for the new version the coverplate will be waiting to be finished.
    But the work must go on and I had to do something today too. :)
    I wanted to do a little work on the ODD frame's outer side. I removed it from the case then I cutted off the tiny 'bumps' i'didnt need to use anymore - to get a smooth surface. As you can see there is a line shaped embosslike something on the side of the frame I didn't removed instead of I use some XPS-like material to make the surface smooth. On top of these there will be an aluminum sheet to get a real smooth surface. This aluminum sheet will be custom painted - soon.
    Updates soon...
  10. Moddingboy
    19 Jul 2011
    Some support packages arrived last week. :clap: Thanks to my Sponsors!
    [​IMG] MSI
    [​IMG] Sapphire Technology
    [​IMG] Cooler Master
    [​IMG] PC Gear
    I wish you all a Merry Christmas! :)
  11. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Great news, my friend! Congrats for the sponsors and the goodies! Merry XMas!
  12. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    Yeah lots of prezzies there to work with, gonna be fun. Your previous work looks so good, cant wait to see more of this.
  13. exexs
    exexs What's a Dremel?
    4 Mar 2010
    the motherboard is just excellent.. thinking about buying the same one for myself.. (thanks Santa)
  14. Moddingboy
    19 Jul 2011
    Thank you for your comments ;)
    Here's a little teaser:
    The plans are done for the paintjob and the masks (stencils) are already done too. Last I wrote about the ODD coverplate so I show you the plan for its' painting.
  15. Sissilisko
    Sissilisko What's a Dremel?
    26 Apr 2012
    Looking really Good! and hoping to see a lot more : )
  16. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Followed your first Gymkhana mod and really liked it. You were actually the one who introduced me to the wonderful DC Shoes videos of Ken Block - and now I'm also going to get a pair of DC Shoes Ken Block "Gatsby 2" in Black/Green Limestone colour. All thanks to you, hehe.
    I love the front grill - was worth the 25 hours, I think. And nice routing/sinking of the sidepanel window - I thought about getting one of those Dremel stands, but I guess a good router bit in my drill press will be able to do the same job.
  17. Moddingboy
    19 Jul 2011
    Sissilisko - Thank You!
    Nutman - Thanks Nutman! In fact its not a dedicated router stand but it worked well so your drillstand will be okay too I think but you need a proper router-bit. :)
  18. Moddingboy
    19 Jul 2011
    -WORKFLOW-
    Day 15: 2013.01.05. / Task: PSU sleeving
    Them plexiglas framing is done but before finishing the PSU coverplate I decided to do some cable sleevings in the weekend.
    Before disassembling the connectors I marked the pins for an easier assembling when the sleevings are finished.
    As you can see I used staples from a stapler for removing the pins - its funny but the work with them were easier than the work with the dedicated pin removing toolkit. :D
    There was luck because the holes on the connectors are big enough to connect the shrinked and sleeved cables (they get little boldy) through them. I have to remove the U-channel from the edge of the hole but the hole wasn't so sharp that I didn't need to file/sand them.
    Day 16: 2013.01.06. / Task: PSU sleeving #2
    Today I have some sleeving on the CPU-Power cables and some fine tuning like removing the sticker from the top of the PSU. The finished power supply get wicked and I hope you like it. :)
  19. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    This is brilliant, cant believe its taken me this long to come across these mods,
    keep it up buddy, i look forward to seeing more!
  20. Nutman
    21 Oct 2008
    Soooo nice!
