really like the contrast between the sheets! the fan feature on the mobotray is really nice - looking forward to seeing some temp differences with the fan on / off. guessing that this would help a great deal more if air - rather than watter cooling is used ?
Thnx, so far I have mainly used DimasTech benchtable and I noticed when I set fan to draw air under the MB that I take off several degree heat with socket.In the cases has not been possible to easily install and therefore the idea. When water-cooled CPU chilling the upper part of the CPU, but there is a build-up of heat and the lower side in solders, so you know you've got a temperature difference and when I finished the project and have tests results cuts here.
5.25" cage, with fan controler and through hole fitings, absolutely suits, on the other hand of cage are going to tank and pump. Next step is sanding and painting.
Great work. I really like the red accents on the front panel/roof. Not familiar with the case so no idea what it is but it looks nice
