Cooling H100 cooler and sabertooth mobo
Discussion in 'Hardware' started by Kovoet, 6 Dec 2012.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    If my cpu is cool enough would my fans stop turning? Or is there something wrong
  2. GeorgeK
    18 Sep 2010
    Something sounds wrong to me... I don't think that the HXXX series can do passive cooling... Here for example they found that "Without any active cooling fans the temperature rose to a dangerous level and so in this test it failed" - although this was with a LGA2011 CPU... What are your temps like
    Kovoet likes this.
  3. Parge
    16 Jul 2010
    It shouldn't stop the fans spinning at any time......
  4. Kovoet
    26 Aug 2009
    Thanks guys. Took my rear side panel off and stuck the lead into another connection and now working normally. Think maybe my PSU is starting to play up, thank god I have a spare.
  5. Parge
    16 Jul 2010
    Yeah, or maybe just a loose connection. Glad you have it sorted!
  6. Kovoet
    26 Aug 2009
    It was weird as i was watching it run normally then now and then just stop running and then come on like 5 minutes later.
  7. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Do you have a fan profile set up in the bios?
  8. Kovoet
    26 Aug 2009
    No bud i have not set it up yet. To nervous to be honest.
  9. Silent_Raider
    Silent_Raider What's a Dremel?
    20 Aug 2010
    For the Corsair H series coolers, you really really should set up the fan profiles in the BIOS. Depending on which generation of cooler you have, you need to plug the pump connector into either the CPU_FAN connector or the CPU_OPT Fan connector. Then in the bios, you need to set the CPU Fan Speed Low Limit to Ignore, the CPU Fan Profile to Manual, the CPU Fan Max Duty Cycle to 100% and the CPU Fan Min Duty Cycle to 100%. That makes sure that the pump is always running at full power.
    The actual radiator fans should be plugged into the H100 pump body, so that it can control the fans via PWM.
    Kovoet likes this.
  10. Kovoet
    26 Aug 2009
    Brilliant thanks will definitely do this
