Scratch Build – In Progress H2O-C7 June 26 Still more Rain! SUX
Discussion in 'Project Logs' started by jhanlon303, 22 Oct 2008.
Guess my weight!
Poll closed 25 Dec 2008.
  1. Less than 2Kg
    5 vote(s)
    14.3%
  2. 2Kg to 3Kg
    21 vote(s)
    60.0%
  3. More than 3KG
    9 vote(s)
    25.7%
  1. The boy 4rm oz
    10 Apr 2008
    Yeah I have seen those plugs before. Antec give them with fans as a 3pin-molex adapter, they are quite good. They save a ton of room and are easy to daisy chain together. Sorry, I can't help you with the whole PSU thing, I'm not that great with voltages.
  2. bradders2125
    bradders2125 What's a Dremel?
    14 Jul 2008
    I would lean towards more than one just to be on the safe side.
    Grevaeg has 1 custom sata power cable powering four HDD's in his 20TB Rig
  3. Cheapskate
    13 May 2007
    I don't think you will be pulling enough juice to need any more than one. Most power supplies have plugs on a single line for 5 drives. You also have a full set of fan jacks on the motherboard.
    The big IF I see is the SATA plug. It has a 5th wire. You might need 2 female molex plugs - one extra for the single orange wire.
    You could also get see if you can 'edit' your 24 pin plug. I know that some of the lines are unused by the motherboard. (Prolly no good. I don't remember any unused orange lines...)
  4. bradders2125
    14 Jul 2008
    You can get Molex to SATA adapters and they only use 4 wires.
  5. The boy 4rm oz
    10 Apr 2008
    Yeah I'm pretty sure the molex-SATA adapters just get rid of one of the black (ground) wires.
  6. jhanlon303
    7 Sep 2006
    Here is what I have found today. I've been off re-installing XP with SP2 for a lan party friend. Now he wants to watercool his DFI LanParty board! I told him see me in a month.
    My Jetway board is rated at 18 watts, it's newer than Cheaps's Mother's build. Appears to have have different caps - same size but different colo(u)r.
    I have 2 Silenx 40mm fans at 12 volts and 0.24 watts each. One res/pump at what unkown voltage and wattage, and one 3.5" 250 Gb HDD, the 12 V LED cannons. All done.
    I have been surfing and digging in my walkin stash closet. The MB has a 20 pin connector - but it has the other 4 pins available but taped over - not needed it appears.
    I have every female connector invented by manufacturers in the last 2 decades EXCEPT the SATA one. I could whack off the SATA connector from the PSU and solder on my own 4 pin female Molex. Why does SATA have 2 grounds when they both go to the same rail internally in the PSU? Current draw? One ground wire not enough current capacity so they use 2?
    Odd.
    Anybody know what the external wires used in a smallish 200-250W PSU is capable of for current? Seems the same size as the 450 - 500W in the closet.
    john
  7. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    That's what she said?.. :hehe:
    Sorry man, it's been a long morning. Good work though :dremel: I've been meaning to get started on something similar, but my car and school has been sucking up way to much time recently.
  8. Cheapskate
    13 May 2007
    The current rating should be printed on the wire. (I know... I can't read print that small either.)
    @Monkeynutz - :thumb: Good one.
  9. jhanlon303
    7 Sep 2006
    No current rating just
    18AWG 80degrees C - 300V
    I'll figure it out. I'm trying to figure the cable lengths(shortnesses) and routing to keep them out of sight mostly. I haven't decided on a single shrinkwrap for the MB connector or individual wire sleeves.
    Not many wires but nice a great surplus of room either. I'll be creative.
    john
  10. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    I wish I could tell ya, John. When it comes to that stuff, I'm all grounds! :D
  11. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    as far as I remember #14-18 AWG can handle 15 amps and more
    but this circuitcalculator com says something else
    there is a link at the top of the page that leads to the calculator itself and there you can change wire sizes and more,
    Alan
  12. bradders2125
    14 Jul 2008
    Congrats on MOTM nomination. Got my vote.
  13. jhanlon303
    7 Sep 2006
    I step away for 1/2 day to help clean and feed the reptiles and Bit-Tech and you guys did this. :jawdrop:
    I want to thank everyone who has voted for me so far. This has been an interest project and has directly involved several other people on the forum.
    Thank you for the nomination. I'll have a small photo update this evening - cable management in a shoebox is tough.
    John
  14. Langer
    Langer Jesse Lang
    24 Jan 2004
    Congrats mate, I just voted for you... but IMO stackart deserves it.
    tee-hee... too late, you missed it.
  15. jhanlon303
    7 Sep 2006
    Might help sway the votes. Then again might not. Depends upon presentation and skill.
    I used to have some of that!:clap:
    My thanks.
    Yo - Bit-Tech! Obscure enough? PM that's not PM might be a hint. Might not. Sleep in fear tonight.
    John
  16. Langer
    Langer Jesse Lang
    24 Jan 2004
    I actually hadn't thought of that... should I <delete>?
  17. jhanlon303
    7 Sep 2006
    I love Bit-Tech! Group Hug!
    john
  18. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    'grats on MOTM nom :rock:
  19. jhanlon303
    7 Sep 2006
    Is great fun!
    john
  20. Langer
    Langer Jesse Lang
    24 Jan 2004
    Muahaha. =)
